Question about Kyocera Mita KM-2050 Printer
ADD WORKSTATION TO SCANNER?? - KYOCERA KM-2050
HOW DO I ADD AN EMPLOYEE'S WORKSTATION TO THE SCANNER OPTIONS?
  • 1,602 Answers
CONTROL PANAL, NETWORKING AND SHARING FOLDER
Posted on Feb 09, 2009
How do I add my workstation to the scanner of the Kyocera Mita KM2050?
You have to make a folder on you computer to scan to. You have to load the scanner file utility on the PC. You have to configure the scanner file utility with the path to that folder. You have to setup the scanner nic with a sender and a destination. The destination has to point to the PC running the scanner file utility by inputting the computer hostname or IP. The scanner nic can be configured with your web browser by putting the scanner nic IP in the address bar. You have to make sure your firewall is not blocking the file scanner utility. For more help go to www.gfbm.net.
Below is a link to the setup guide on the manufactures website.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13314&rid=13433
Feb 07, 2011 | Kyocera Mita KM-2050 Printer
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
MY PC DON'T DETECT THE SCANNER FROM A KYOCERA 2050
First make sure you have a scanner on this machie. The scanner NIC is an option for this machine. If you press the Scanner button on the panel and nothing happens then you most likely don't have one. There is a network connection for printing that is standard that is located on the right side of the machine. If you have a scanner on the machine there will be a second network connection about 6 inch above the printer network connection. It sounds like you don't have the scan option.
Feb 26, 2010 | Kyocera Mita KM-2050 Printer
Royal (Kyocera) KM-2530 Need to add workstation to scanner funct
Go to www.kyoceramita.com for software. Make sure you select the proper software specific to your model and computer operating system.
Dec 01, 2009 | Kyocera Mita KM-2530 Laser Printer
KM-2050 / error c3100
C3100 Scanner carriage problem
• The home position is not correct
when the power is turned on or copying
the document placed on the contact
glass. Poor contact of
the connector terminals.
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
Sep 30, 2009 | Kyocera Mita KM-2050 Printer
Kyocera KM-2050 scanner
You normally enter this information using your web browser and typing in the IP address of the scanner.
Hope this helps.
Jul 02, 2009 | Kyocera Office Equipment & Supplies
Kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Mar 08, 2008 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-2050 Printer Logo
433 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
