Question about Canon imageRUNNER 2270 Copier
Imagerunner 2270 prints with spots
Just installed new toner - is there something i need to clean to get rid of spots from every print job???
thank you for immediate attention - i am trying to run a youth program and need to print ASAP
  • 135 Answers
You can try to clean your scan glass and optics if that does not work you will have to call tech
Posted on Apr 19, 2009
Canon Imagerunner 3025 B&W is printing what looks remants of an old ink each time we print out something? Like the rollers need to be cleaned? Any advice on how to solve ourselves?
There are 2 possible things that could be at fault here. One being the image is'nt fusing to the paper due to faulty operation of the fuser. If any of the toner/image on the paper is easily wiped off the paper then this is more than likely the issue. The second possible issue is that you have a bad drum unit, there is an internal cleaning blade that is used to scrape the excess toner from the last image off before creating another copy. On this particular machine the drum only comes as a unit and would need to be replaced. More than likely you need a new drum unit. P/N- 9630A003AA
Mar 09, 2012 | Canon ImageRunner 3025 Black and White...
Thank you Kitty but I'm not clear on how cleaning the Print Heads and replacing toner would fix this faded banding issue. I printed long Vertical bars of Magenta, Cyan, Yellow and Black. All colors fad at...
you need to clear the rollers and the heat drum (fixes the image and melts the toner onto the paper) if you have done any two sided copy, or have used paper with an image on one side, the ink may have gotten onto the roller and left a trace which would account for the banding being in the same place all the time. the rollers and etc are difficult to get at, and not really a job for amateurs
Mar 10, 2011 | Samsung Office Equipment & Supplies
Hai iam bala, my Canon imageRUNNER 2270 prints but printed letters are erase,
problem with your driver and uninstall the driver and reinstall the driver and second thing remember
Oct 29, 2010 | Canon imageRUNNER 2270 Copier
My copier machine is printing out black lines.
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on emma.servis@gmail.com.
Hope that helped!
Jul 30, 2010 | Canon imageRUNNER 2270 Copier
Computer reports print job is going to imagerunner but pringint has stopped. There is paper but screen report receiving data a nd processing, nothing coming out?
Do you have selected right paper format on printer properties on PC? If you have A4 in machine and under print prop eg LTR the machine will report problem.You can then manually select on copier eg tray 1 and copier will print the doc on format from tray 1.
Oct 21, 2009 | Canon imageRUNNER 2270 Copier
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
Black toner spots appear on print outs
You have something stuck on your drum. See page 125 of your manual to clean it--it's just isopropyl alcohol on a Q-tip, but don't scrub. This happens (too) often to some people I know.
Apr 11, 2009 | Brother MFC-8460N All-In-One Printer
Yellow Toner Ink Spotting
Take a tissue and clean the area where the toner is. Do not use anything wet at all. Just a soft tissue. Re-install toner and try again to print. If the problem continues, it may be a leaking toner catridge. The cartridge has a cleaning blade built in and it may be deffective. Try a new toner cartridge if so.
Feb 11, 2009 | Brother DCP-9040CN Laser Printer
Canon imageRUNNER 2270 Copier Logo
134 people viewed this question
old marine
old marine
