Question about Boston Acoustics BA7500 Computer Speakers
No power to my subwoffer
I need a new power supply... Model No. DM1203AO-1AN... 12v AC.. MY output of my xfrmr ie 3.5v for my Boston speakers. My subfoffer has no power indicator
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
Posted on Jul 16, 2009
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
I don't have the AC DC 12V in (power cord). What kind is it?
Not only do you need the correct voltage and amperage (MAH) but you need the corectly sized plug to fit the socket AND it has to be in the correct polarity. Usually the polarity is marked by a broken circle with a dot in the middle. Leading to this dot will be an arrow or just a line and at the other end of the line will be either A positive (+) or negative(-) It's important you get this polarity correct when plugging a new power supply in.
Your local electrical store should be able to sell you either a fixed 12volt supply or even a variable supply allowing 3, 6, 9 or 13 volts output. Make sure it has the amperage capacity you need. It won't matter if you need 500Mah and the supply is 750Mah as long as it isn't less than what you need.
The power supply should come with an assortment of plugs which are insrted into the socket on the end of the power supplies lead. Follow the instructions on the packaging and ensure you have the center pin set as either + or -. If you are in doubt. Take your speaker which has the socket fitted and show the salesman. He should be able to pick the correct plug and make sure it's the right way around.
If you plug it in and nothing lights up, quickly remove the plug and turn it 180 degrees in the power lead socket. Obviously it's been put in the wrong way round. If you were quick enough no damage should have occured and away you go.
Just one tip. Wrap a small piece of insulation tape around the plug to stop it from being pulled out of the power lead's socket. They do tend to work loose after a while. Oh and make sure it's switched to 12 volts if you get the variable one.
Apr 25, 2010 | Boston Acoustics BA65 Computer Speakers
I need a new plug for 12V in AC/DC
I will presume you mean power supply
In which case a "universal power supply" will do the job fine so long as you remember 2 important things.
1. Voltage this you already know and lots of universals go up to 12V
2. Current rating. this is just as important as 1. check on your speakes or old PSU that information should be on there somwhere nd itwould lok like 250mA or 500mA or whatever the rating is. it is important to make sure that your replacement is the same or even a little higher if your speakers are 250mA then it is safe to go to 500 mA.
If you just want to solder a new end on then radio shack, tandy, the source are just a few of the places you will find what you want.
If this information was useful please click
Aug 14, 2009 | Boston Acoustics BA735 Computer Speakers
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Can i power my 12v computer speakers with my computer power supply
Generally NO.  Most computer speakers are self powered.  The speaker output from the computer is only enough to power headphones.  However, you can plug that into a stereo and then use the speaker attached to the stereo output.
Mar 15, 2009 | Boston Acoustics BA65 Computer Speakers
Speakers
The Boston Acoustics power supply that came with Model 7000596 speakers is rated:
Input 120VAC 60HZ 23VA
Output 12VAC 1500mA (1.5A)
The PS model number is WK1201A5-1AN
Dec 28, 2008 | Boston Acoustics MicroMedia Computer...
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me bostonrox129@yahoo.com
Aug 28, 2008 | Boston Acoustics MicroMedia Computer...
Problem with boston acustics subwoffer
> check it in another computer
> if problems persist check setting of speaker also connectivity
Dec 02, 2007 | Boston Acoustics MicroMedia Computer...
Boston Acoustics BA7500 Computer Speakers Logo
258 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
