Question about Kenmore 73952 Gas Dryer
New thermostat, still won't heat
Kenmore electric dryer series 70 won't heat. New thermostat installed.
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Okay...now I'm confused. Listed under GAS dryers, but asks about an ELECTRIC Dryer problem. I guess I need to learn to read...
  • Jeff Rockwell
    READ the question. This is for advice on a GAS dryer. There is no heating coil.
  • Jeff Rockwell
    Have you checked the igniter?
  • 547 Answers
Heating coil broken
Posted on Feb 11, 2009
Kenmore 70 series dryer squeaked, heated, drum turned, then turned off and won't come back on--is it toast or worth fixing?
It all depends on how you look at things.
Comparatively speaking, dryers are a piece of cake.
However, with out mechanical ability and tools, it could be over your head.
You decide.
If you choose to fix it yourself, it could be done for a few dozen dollars.
Hiring a repair man could make it cheaper to buy a new one.
New parts are available through "Sears parts" on the internet.
Someone will need to take it all apart to see why it stopped on you. To do it yourself, you may also need an electrical testing meter.
Be blessed.
Mar 20, 2013 | Kenmore Dryers
Electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Nov 05, 2010 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Have a Kenmore 70 series electric dryer, runs great but is not getting heat? What should I do to fix this?
#1 make sure you have 240VAC at the dryer
#2 check the heating element and/or the thermostats
Jun 08, 2009 | Kenmore 62882 Electric Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 73952 Gas Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
