Question about Gateway 450ROG Notebook
Emergency Shutdown & GWSCAN Error code 0226 Sector Relocation Err
I have a Gateway T1620 Notebook. Randomly the system shuts down, showing a blue screen saying it did an emergency shutdown to protect the system & to check the memory and possibly uninstall any new software. I don't think it is software related.
BigFix had been suggesting running the GWScan program so... the Extended Test on the C drive, a Hitachi 4TS542525K9SA00, came up with the error code 0226, Sector Relocation error.
I am wondering if the shutdown is being caused by that error.
If there is a solution other than replacing the drive...
If not what do I need to know in order to do the job myself?
Thanks in advance.
  • 1,602 Answers
GO ONLINE AND TYPE IN THE FOLLOWING INFOR MATION:
RELOCATION ERROR 0226
I MADE THE MESSTAKE OF TYPING IN 0026
ROD
Posted on Feb 09, 2009
My Gateway 7405 randomly shuts down. It does not matter how long it has been running for. It has shutdown during bootup and after running for many hours. Just before it shutsdown the fan accelerates to...
You might try changing the Power Options (its in the Control Panel) Properties so that all windows are set to NEVER. That is, so that it will never automatically turn off monitor, hard disks or go to standby. Also turn off all the alarms. This worked for my Presario R3000 running WinXP Sp2 which would shut off for no apparent reason. Having said that, you should blow out your fan with compressed air occasionally. And check that your power cord is OK. When you pull out your power cord, the battery icon should show operation.
Feb 12, 2011 | Gateway 7405GX Notebook
My dell inspiron 1525 notebook keeps shutting down everytime
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 23, 2010 | Dell Inspiron 1525 Notebook
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Jul 05, 2010 | Gateway CX2618 Notebook
Computer shuts down as soon as lcd screen power start. after repeated attempts it may start but then shuts down in approximately 5 minutes
Well i had a similar problem..... it would come as normal and work for a wile then eventually would randomly show a checksum header error and eventually told me the problem i managed to do a system restore this morning and it work then i went into safe mode and shut down (this will make it remember it last time booted up successfully) :)...... then i pressed f2 which opened the BSOD then i pressed load default setting....... then press save and exit .... i let it boot up and it worked this time i had a new beep code 1 2 1 :) which is good as it used to be 1 4 2 1 but on my compyter i logged on and i had a program called advanced system care in here is a registry cleaner and other tools it's free to use once installed goto overview then tools then admin tools and click system file checker this will verify any failures and if it finds any it will fix them or either you're laptop may have an hardware problem so =/ gl i kow this aint nothing to do with but it's similiar but at least try :)
Dec 14, 2009 | Gateway P-7808u 17" Notebook PC
While trying to bootup my harddrive makes this clicking noise, and shows a message operating system not found, how do I correct this problem
Hi Mark,
The above message seems to hard drive issue. I recommend you to check with GWSCAN link. GWSCAN will isolate the issue with hard drive or not. http://support.gateway.com/s/HARDDRV/Misc/GWSCAN512/GWSCAN512su46.shtml
I believe above link will help to confirm your issue.
Sep 28, 2009 | Gateway M640XL-QS Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Gateway 450ROG Notebook Logo
1,504 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
