Question about HP Wireless Optical Mouse
Mouse doesn't work
My wireless optical mouse does not work. the red light is on, the usb connection lights up, but i can't get the mouse to work. the cursor will not move. I've tried changing the batteries with no success.
Thank you,
Jeffrey Helfand
  • 5 more comments
  • jhelfdo Feb 09, 2009
    Got it! Thanks so much, Rod.
    Best regards,
    Jeff Helfand
  • Anonymous Feb 15, 2009
    THANKS!!!!!!!!!!! IT WORKED!!!!!!!!!!!! I was about to throw my mouse across the room after fiddling with it for quite some time.
  • The Wallys Feb 28, 2009
    HP wireless Mouse plugged into USB. Mouse lit on the bottom. Right and left buttons work, but mouse won't move.
  • Anonymous Mar 15, 2009
    It worked! I didn't know there was a reset button on the USB connection. The instructions that came with it didn't show it - or else I couldn't figure it out from the pictoglyphs. Thank you.
  • TOY4EVA Mar 18, 2009
    I CAN'T USE THE MOUSE EVEN AFTER PRESSING THE RESET BUTTON ON BOTH THE BLUETOOTH AND THE MOUSE SIMULTANEOUSLY.
  • Anonymous Mar 24, 2009
    usb connection ligts up but drive is not found mouse does not move
  • Anonymous Mar 18, 2014
    I put new batteries in but the cursor will not move on the screen
  • 1,602 Answers
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Posted on Feb 09, 2009
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
I have a Mini Wireless Optical Mouse. M/N M-RAD92. I just changed batteries. The mouse is lit up, but the USB port stick's light will not light up and the mouse is no longer worker.
usb stick doesn t light also on mine but works perfectly. press once on stick button and once on mouse "setup" button and they will connect.
Jan 31, 2011 | Labtec Wireless Desktop Keyboard/Mouse...
My Micro Innovations Wireless Optical Travel Mouse doesn't seem to be responding. I plug the usb receiver in and try connecting. The usb glows red and the mouse's laser red light is on all the time. It...
Try to use it on another computer to isolate if the problem is the mouse or the software on your computer.
If the mouse does not work in another computer, then the mouse is defective.
Is the mouse does work in another computer, then reinstall the drivers on your computer.
Go to the manufacturer website to download the appropriate drivers
Thanks
TechSaver
Jan 21, 2010 | Micro Innovations Wireless Optical Travel...
I have tried 3 fresh, new batteries
What is the exact model of wireless mouse you have? You may have a laser wireless mouse, which may not emit any visible light. The red light on other wireless mice are either a different optical mouse technology, or a red light for the purpose of being pretty. Not all wireless mice have a red light that you can see. Does the mouse work (regardless of the light)? Have you hit the connect button? Have you connected the wireless receiver to a working USB port?
Jul 18, 2009 | Microsoft Wireless Notebook Optical Mouse...
Not working
dear,
The small notch in usb device socket under the mouse could be malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
dont forget to rate it
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Mouse Wireless Model 1023/1024 won't work
try using an eraser on the contacts if you can reach them. Sounds like dirt/corrosion build-up.
Jun 15, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Not Connecting
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Apr 05, 2008 | Microsoft Wireless Notebook Optical Mouse...
No Cursor
Did you register the mouse to the receiver? There should be a button on the receiver, the bottom of the mouse or both used to connect the wireless mouse to the receiver. Also, if you do not have a red light on the bottom of your mouse it may have a battery problem.
Jul 22, 2007 | Logitech Optical Mouse Plus Usb Port...
HP Wireless Optical Mouse Logo
1,359 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
