Question about Desa International Variable Propane Forced Air Heater
Burneer wont stay light afer lighting
When you release start switch burner shut down! I changed termo couple, burner still does not stay on. Would the termo disc be the problem. Is ther any way to test these parts?
Thank You
Keith Danner
  • padanner Feb 09, 2009
    The thermocouple I purchased was the # that it call for in the owners manuel. and the wires are both the same color, so I do not think it makes a different wihich way they are hooked up. I do not have a voltage meter to check the thermo disc.
    Thanks you
    Keith Danner
    President:
  • 1,902 Answers
You can test all the parts with a multi meter, My only concern is that the thermocouple you got is either not the right one, or it is wired wrong and the wires may need to just be switched around, if that doesnt work then take a multimeter and check for voltage at the Limit switch (thermo disc) and see what you get, you can also check to coninuity at the limit switch if it is opened or closed, if it is closed replace if it is open then it is still good
Posted on Feb 09, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
Good Morning, When I turn the control valve to the on position, the burner will light, and after 5 of 6 seconds it will go out.
if holding the button down for one minute. and then release it and it stays on for about 5 seconds, the thermal coupling is bad. if bad, it will shut off gas supply to burner, for a safety precaution. good-day !
Nov 27, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Flame goes on than out and keeps doing that wont stay lit!!
I'm assuming you're referring to a gas burner that supplements the heat pump. If the burner lights at all, The ignition system is working. If you need to reset it for it to relight, I would suspect the thermocouple. It detects the flame to prevent gas from pouring out of an unlit burner. If it malfunctions, the control thinks the burner didn't light and shuts down for safety.
Nov 26, 2009 | Weather King 10AJA6001AH Air Conditioner
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot light wont stay lit.want to clean the orifice
You shut off the gas.
Shut off the power.
Remove the gas valve and burner assembly.
After cleaning and reassembly you must purge the system and use a gas leak detecting soap to verify no leaks before turning on the power.
Apr 15, 2009 | Heating & Cooling
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
93 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
