Question about Philips 32MF231D Television
CAPTION WILL NOT TURN OFF
MODEL 32mf231D\37
    Sergeant:
    Champion:
  • 289 Answers
Hi..To turn off the captions u have to go to
the settings in the television.There will be
a option in the tv to turn on or turn off the
caption.If u do not need it u have to turn
off that.
check it out..
thank u..
rate me..
Posted on Feb 09, 2009
2 Suggested Answers
SOURCE: television model number 32mf231d/37
I have the same problem with the same tv and the problem almost always is at least one blown capacitor on the power board of the tv. U can see for yourself. (be sure the warranty is up for your tv first, if not get phillips to fix this for you) remove the back cover and then the metal top that cover the power board (you will see the red yellow and white AV plug jacks) in there is the power board, you can tell whether or not the capacitor is blown by looking at the top of it, it will be bulging out or leaking. This is an easy fix, u can get new capacitors from radioshack or stores similar to it.
Posted on Sep 04, 2010
My magnavox 32mf231d/37 tv will power up and the sound works, but the screen is blue... any help would be great!
Blue screen means no signal detected which if you have audio is strange---How and where on the set is the signal hooked up?
Coax or cable fitting?
Rear audio and video or component or HDMI?
Mar 13, 2012 | Philips 32MF231D Television
How do i shut off the closed caption ?
Hi, if you have the original remote control unit, look for the key denominated "cc" close caption and press it once at a time until the caption indicates "off".
Nov 29, 2010 | Protron PLTV-37 37 in. LCD Television
Television model number 32mf231d/37 does not want to turn on
Aug 16, 2010 | Philips 32MF231D Television
I have a philips 2005 tv model number 2DPT6441/37 closed caption stays on when we first turn the tv on. I can turn it off with the remote by hitting the cc button.
I'd be interested in the solution also my 20PT6245/37 (also a 2005) recently started doing this too. There must be some reset somewhere unless something fried. I use a universal remote, so noe I had to get the Factory remote back out, more of an annoyance now.
They don't build them like they used to ... Zenith Space Command SA 1923W (1984 Model) still going strong with a beautiful picture! Looks & works like new.
Apr 08, 2010 | Philips Televison & Video
Everytime I turn on the tv the closed caption is on
turn close caption off turn off tv, unplug tv and plug back in
Nov 13, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 32MF231D/37
Hold a flashlight up to the tv while the tv is on. If you see a picture your CFL is burnt out.
Mar 21, 2009 | Philips Televison & Video
Power Supply Keeps Tripping Fuse
Freeze the capacitors is a trick worth trying. These usually are the problem
the way you run this is too use freeze spray to freeze each capacitor one at a time . Turn the TV on and if it doesn't trip for a few second longer you know that is the capacitor to change. Freezing capacitors only helps identify the fault if it is a capacitor issue (usually is with power on TV's)
Dec 24, 2008 | Philips 32MF231D Television
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
Mar 07, 2008 | LG 37LP1D 37 in. LCD Television
Televison & Video Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
