Question about Brother MFC-7220 Laser Printer
Faxtelephone brothermfc-7220 I have lost my manual instructions and i want to put my fax in fonction with tel/fax. Can you tell me pleau what i have to do. I can't receive fax . Thank you. metik9@telvic.net
    Genius:
  • 1,913 Answers
MFC 7220 Brother Fax machine keeps telling me that the Drum is not working. we've moved the blue tab a million times and still nothing... it's not turning right. Are there other things that we...
I recommend replacing the drum unit with a new one. Do not forget to follow the instructions on programming the unit to recognize the new drum unit. Otherwise you will still be faced with the message to replace your drum unit.
Sep 20, 2011 | Brother MFC-7220 All-In-One Laser Printer
What cable do I need to hook up my MFC-7220 fax machine so I am able to scan with it?
USB Printer cable is supplied along with printer.
If the original cable lost then you can buy a cable from any computer shop
Alexander
Apr 14, 2011 | Brother MFC-7220 All-In-One Laser Printer
How do i change from manual receive mode to auto?
You want "Fax/Tel" Mode. To do this follow instructions below.
To set a receive mode follow the instructions below.
a Press Menu.
b Press a or b to choose Initial Setup.
Press OK.
c Press a or b to choose Receive Mode.
Press OK.
d Press a or b to choose Fax Only, Fax/Tel, External TAD or Manual.
Press OK.
e Press Stop/Exit.
The LCD will display the current receive mode.
Apr 04, 2011 | Brother MFC-465CN InkJet Printer
Unble to receive a fax
It may be a silly question but it is a common error have you checked the cable is in the line socket and has not been put into the tel socket on teh back of the fax machine as this will cause a fault.. youcan check this also by dialling the fax number and see if it rings out.. also check the rx reception mode is set to fax and not tel/fax or manual setting this is on the display it should have the date and to the right say auto or fax make sure it isnt displaying tel.. Letr me know if this helps
Jul 12, 2010 | Brother MFC-7220 Plain Paper Laser Fax
How can I print a history report on my Brother MFC-7220 Plain Paper Laser Fax?
The report you want is called "Fax Journal, and it's number is 4.
Press "Reports" button (in the upper-right corner of the panel), then either go down (using up/down arrow keys) to "Fax Journal", or press number 4 directly, then confirm with "Menu/Set" key.
By the way, click here to download a PDF manual for your unit.
Good luck, and please leave testimonial if helped :)
Jul 06, 2010 | Brother MFC-7220 Plain Paper Laser Fax
I have a MFC 7220...today it will not send a fax
You need an ANALOG phone line for faxing, not DIGITAL.
Mar 19, 2010 | Brother MFC-7220 Plain Paper Laser Fax
Manuel feed
If it says manual in the display it means the fax is in the manual mode where you have to press the button to answer fax manually. You just press the mode switch until it says fax only, fax/tel, or manual. It only does manual feed when you place a blank paper in the front slot.
Aug 19, 2009 | Brother MFC-7220 All-In-One Laser Printer
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Not receiving a Fax?
lost instruction manual for sagem philps magic 3
Apr 03, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 Laser Printer Logo
131 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
