Question about P.I. Engineering X-keys (XF-10-US-R)
Unable to find PIBus.sys
Our customer has run to X-key devices for a couple of years now on two Windows 2000 clients without any problems.
Today the got these messages on both clients.
"Unable to find PIBus.sys"
and
"No X-keys found. Please plug in your X-keys device or check Device Configuration from Options Menu."
Windows Update is disabled, and the IT-department claim they have not touched the clients.
What could be done to fix the problem?
/Harald
Sony VAIO PCV-RZ54G PC Desktop keyboard errors in event viewer
The I8042prt.sys is a system function driver found in Microsoft Windows 2000 and later versions for PS/2-style keyboard and mouse devices. If I8042PRT.sys is disabled or missing from the Registry this could be the cause. First check in Device Manager, a black exclamation point (!) on a yellow field appears next to these devices?
See if you can update the driver.
Lets check your registry. Here is the key: HKEY_Local_Machine\System\CurrentControlSet\Services\ i8042prt:Imagepath=System32\Drivers\i8042prt.sys
It should be there can you check to see if it's still there? Here's how:
Click Start > Run > Type: regedit
When Registry editor opens expand local machine> system >CurrentControlSet> Services> (Scroll down till you see i8042prt and click on it.
And tell me what the data entries for Start (should be 1)
Then expand the i8042prt key and select "Parameter" tell me in detail listed for the layer drivers; exactly what you see then select "Enum" Tell me if you see a file name "1" and data: ACPI\PNP0F13\4&1506bb2e&0
We might have to enable or add the port.
I'd suggest running a repair if you have your windows installation disk or do System Restore in Safe Mode, if unable to do it in Normal Mode.
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, pick a Restore Point before your problem started (if there's a restore point that goes further back prior to your malware issue I'd suggest that restore point)
Here's how to access system restore:
Click Start > Programs > Accessories > System Tools > System Restore > pick a different time > Next > etc
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
If none of the above works you should seriously think about switching to a USB mouse and USB keyboard. The i8042prt.sys driver is ancient and it only controls PS/2 mice and keyboards (Doesn't affect anything else).
Jun 25, 2012 | Sony VAIO PCV-RZ54G PC Desktop
My Usb driver do not recognize error 0000002b I have already tried many types of solution but always says usb did not recognize or an unknown port connected tu yr Computer please tell me easy way of...
Deploying endpoint software to Windows 2000 clients returns the error 0000002b to the console Symptom
You are unable to deploy client-applications to Windows 2000 client-computers. The following error message is displayed in console:
0000002b The installation credentials you entered in the 'Protect computers wizard' are either incorrect or do not give administrator access to the computer over the network
Known to apply to the following Sophos product(s) and version(s)
Enterprise Console 4.7.0
Enterprise Console 4.7.1
Sophos Enterprise Manager 4.7.0
Sophos Control Center 4.1
Sophos Control Center 4.0.1
Enterprise Console 4.5.0
Enterprise Console 4.5.1
when one or other of these consoles is installed on any of the following operating systems:
  • Windows Vista
  • Windows 7
  • Windows 2008
  • Windows 2008 R2
What to doPlease refer to the Microsoft Knowledgebase article http://support.microsoft.com/kb/239869.
NTLMv2 must be enabled on Windows 2000 clients. This can be done in one of the following ways:
  • Enabling NTLMv2 in the registry:
    open the following registry key,
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
    and ensure that the value of 'LMCompatibilityLevel' is set to a value of '1' or above.
  • Enabling NTLMv2 via Local or Group Policy:
    This is described in the Microsoft Knowledgebase article: http://msdn.microsoft.com/en-us/library/ms814176.aspx.
Sep 11, 2011 | Computers & Internet
I cant find the driver for my samsung intercept. I would like to connect to my computer but the S3C6410 ANDROID ADB doesn't work
Here is what I have found. You cannot let windows automatically install. You must answer no to automatically install and do it manually. So try downloading this link and unzipping it where you can find it. And then point the install window to this .inf file.
a somewhat official answer is all your problem is lack of androidusb.sys, which located in windows\system32\drivers\, it was deleted or replaced by installing some other android related usb client drivers, however, when you install it manually by pointing it to the android_winusb.inf, it do copy the .sys file into system32\drivers\ again, so when come across with this problem, remove target client device keys (with the VID/PID) in registry in currencontrolset/usb/enum, then better restart windows , and run .exe file to install driver or install it manually, and if you can get the right androidusb.sys from your driver directry (for example c:\progrm files\htc...), you can just copy it into system32\drivers\ but complicated.
I cannot vouch for this file but it looks legit. CaptivateADBDriver xp.zip
Feb 02, 2011 | Computers & Internet
Where can i find Windows 2000. It drives me to crazy, i have wi-fi card which is compatble with windows 2000 and i need to set that card today :( Anyone can help? My laptop model is Acer Travel Mate...
If the card is compatible with Windows 2000, it probably is compatible with Windows XP.
If not, access the manufacturer's web-site, and download the device-driver for Windows XP for the device.
May 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
Siren Edge 4 gig Boot error,
Siren's software support is bad, but you can call them: 254.224.0222
Sometimes reformatting a player can cause key system files to be lost - this particular mp3 player does not have a recovery tool or a firmware upgrade that I know of, so you can try the Windows Recovery Method: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Let me know how it turns out.
Jun 13, 2008 | Siren Edge MP3 Player
Unable 2 run jetflash on windowsme
Your op sys info would help greatly. If you have windows 2000 or above it should see it. If you are using anything earlier reinstall the drivers. If you dont have the disk go to the flashdrive manufacturers website and download it. You mite also try to uninstall any sign of it in device manager and reboot....
Apr 10, 2008 | Computers & Internet
Problem regarding ActiveX control
Do you have this problem in your server2003 sys or the client sys.
Jan 02, 2008 | Microsoft Windows Server Standard 2003 for...
Problem installing operating sys....
Stop Messages During Installation An unsuccessful attempt to install Windows 2000 can result in a Stop message. When this happens, first check that the computer and all of its peripheral hardware are compatible with Windows 2000. To do this, refer to the latest Windows 2000 Hardware Compatibility List (HCL). Microsoft compiles the HCL through rigorous component and compatibility testing of computers and peripheral hardware to determine if they work well with Windows 2000. For more information about the HCL, see "Additional Resources" at the end of this chapter.
If the hardware you use is not included on the Windows 2000 HCL, contact the hardware manufacturer as a first-line resource for available information, newly tested hardware, and Basic Input/Output System (BIOS) and firmware revisions. Reducing the number of hardware components by removing nonessential peripherals and devices can help you pinpoint installation conflicts as well.
Nov 28, 2007 | Microsoft Windows 2000 Professional for PC
P.I. Engineering X-keys (XF-10-US-R) Logo
369 people viewed this question
Top P.I. Engineering Video Game Consoles & Games Experts
James Wishart
Are you a P.I. Engineering Video Game Console and Game Expert? Answer questions, earn points and help others
