Question about Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine
No Steam, No Water
I have a problem wuth my machine, gaggia espresso color
there is no steam getting out and no water from the pipe
How can I fix it
Thanks in advance,
Kobi
    President:
  • 1,618 Answers
Try descaling the machine, there might be some mineral buildup preventing the machinefrom working.
Posted on Apr 15, 2010
Hi, the hot water outletpipe( i don`t know how to say it in english) keeps leaking water. If the machine is heating up, tehe pipe allready starts leaking and keeps doing it. The machine is only 8 months...
Do you mean the "steam wand" ? The pipe you would use to steam milk?
That sounds like the steam valve needs replacing or rebuilding. If the machine is only 8 months old it is still under warranty. You should contact the store where you bought it or contact Gaggia service center in your country.
Sep 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine Logo
185 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
