Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Need thermostat for 170t reddy heater - Reddy Heater-170,000 BTU Kerosene Deluxe
YELLOW FUSE BLOWN NEXT TO FAN MOTOR
Posted on Feb 10, 2010
  • 92 Answers
Reddyparts.com still has most parts for reddy heaters even though reddy heater went out of business in 98.
Posted on Feb 10, 2009
burdfrenzy
  • 348 Answers
SOURCE: I have a reddy heater 170T heater I need an
I just saw some on eBay. Put in reddy heater part in search. Hope they fit yours.
Posted on Oct 15, 2009
jyackle5
  • 8197 Answers
SOURCE: how may i get a owners manual for the reddy heater
You can get the manual here on link below.
http://www.fncuthbert.com/pdfs/masman1.pdf
Good Luck
Posted on Nov 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I need a owners manual for my reddy heater 170t,
I think the actual model number for this is RL170AT
This is a DESA manual but the same exact model except for the name:
http://assets.phpdistribution.com/manuals/Manuals_Page/113170-01E.pdf
Over the years DESA INTERNATIONAL has manufactured kerosene heaters with the following brand names and Reddy Parts stocks parts for them all:
  • dayton%203e218cred.gifReddy
  • Koehring
  • Knipco
  • Amoco
  • John Deere
  • Dayton
  • Queen Bee
  • Co-op
  • and many private label brands
If you ever need parts here is the source:
http://www.reddyparts.com/
Thanks for choosing FixYa,
Kelly
Posted on Nov 19, 2010
  • 67 Answers
SOURCE: sometimes the heater throws out raw fuel out of
turn the adjustment srcew clockwise a little to raize the pressure.. check your gap on the spark plug /igniter .060. also check the air pressure should be 6.5#
Posted on Jan 23, 2011
tbugger
  • 232 Answers
SOURCE: Reddy Heater 170T works fine with the cover off
First, heaters with Hot Surface Ignitor technology MUST have the air pump pressure set to factory specs. The onboard computer will not allow any deviation. Proper fuel delivery depends on it.
Now, if the pump pressure is correct, there are no leaks between the pump and the nozzle and no vac leaks on the fuel line, the 90% of the time the problem is a worn nozzle. Desa recommended annual replacement of the nozzle simply because of the wear factor.
More troubleshooting tips
Posted on Nov 01, 2011
Reddy heater 170T- terrible fumes-fuel pressure problem
Are you sure there is not water in the tank? Fuel pressure should almost never need adjusted.
Jan 08, 2014 | Reddy Heating & Cooling
Reddy heater 170T ignitor (#PP200) not glowing at start up.
if its the ceramic glow rod they brake easy and cost 40.00 plus some times usually broke down next to the base ceramic only ever had one power supply go on me but hard to dignose
Dec 09, 2013 | Heating & Cooling
Sometimes the heater throws out raw fuel out of the burner and sometimes if I cut it off and wait a little bit it will ignite and come on and then it will work normal with the thermostat. Is there...
Jan 23, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a problem with my reddy heater 170t. it fires up runs untill it reaches set temp.but when it goes to restart the motor runs bacwards?after i manualy turn it off/on 2-3times it fires back up...
The thermostat is not the problem. The motor has a starter capacitot attached that gives the motor a burst of energy to get it going the right direction. It is not doing its job. The motor must be replaced.
Nov 27, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
WHAT IS THE CORRECT NOZZLE SIZE ?
PP223 is the correct nozzle for all 170T Reddy heaters. Click on this link.
Nov 05, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Sincerely,
Shastalaker7
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy heater 170T heater I need an Igniter for it can you help
Oct 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light
Are the ignitors intact? In other words, does the element make a loop back to the ceramic portion. The purpose of the LED is to notify the user of a defective ignitor. The other possibility is a bad control board.
If the ignitor is intact, but no power coming from the board (ignitor only glows for 5 seconds), then the board is bad or the fuse is blown. You might want to test the photocell while you are at it.
You will need to locate the correct model numbers to order the correct parts. "170T" & "125T" are only part of the correct model designation.
Post back if you have further questions.
Oct 23, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
281 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
