Question about Dell 1710n Laser Printer
2 springs in the back of the printer
Had to take printer apart because of a lost screw inside in the interior of the printer. am now putting the printer back and am unsure how the springs are to be placed on their roller. please reply.
  • 1,602 Answers
CALL A SERVICE TECHNICAIN TO REPAIR IT PROPERLY
THANK YOU ROD
Posted on Feb 09, 2009
How to put the the springs back in the canon P1500 after cleaning ink waste absorbers?
i just lined up the main housing, put the 2 screws in the front (did not screw in the 3 side screws) ( tried it when the housing was off the springs would just fall down)
just slide the springs in after it is screwed in the short side fits into the white plastic you will see grooves where it lines up on the white plastic piece, the long side of the spring hooks on to the back metal hook on the other side the coil rests in the middle of the prongs
Jul 06, 2014 | Canon PIXMA iP1500 InkJet Photo Printer
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
2004 Mercury Monterey tail gate handle came completely off. The left side's guide is in place, but the right side is retracted - hence can't just put it back in. Any ideas?
Open tail gate. Use the access square inside - pull cable to open tail gate. Remove interier panel - 2 bolts plus 2 screws (2 bolts on handle and 1 screw each side), pull remainder out of guide clips. Now have full access to locking mechanism. Identified a retaining spring had come loose sending guides to shift left (exterior point of view). Place hand in tail gate and move guides over and put spring in place to retain. verify it works and put back together. Handle is the trickiest part as the bolts have to go through the interior panel and afix to the metal tail gate.
Sep 20, 2009 | 2004 Ford Freestar
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Rope won't recoil. i can jiggle it back in.
Clock spring either broken or un-hooked in inside of pull assembly. you have to take it apart and either re-attach spring or replace spring. Interior of assembly shoul;d be available on-line. You should have model # available.
Aug 21, 2009 | Toro Lawn Mower With Toro Power Tools
Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up and down. Now, you need to use a utility knife and cut the blue rubber off of the spring. Once you have the blue rubber but off you can see a large spring with another smaller spring inside. Push the head of the ******** till the larger spring's coils are an 1/8 to 1/4 of an inch apart. Next take either the small slot head screw driver or a pair of needle nose and jam the smaller spring back into the hole in the center of the white plastic piece inside of the larger ring. Next plug it in to make sure the vibration is working, reattach the silver piece and tape the larger spring with electric tape.
Oct 25, 2008 | Hitachi Magic Wand Hv250r Hand Held...
Load/Remove Paper Light Flashing
IF THE ROLLERS DON'T TURN AND MAYBE YOU HEAR A CLICKING NOISE FROM THE LEFT SIDE OF THE PRINTER, THERE IS A SPRING CLUTCH INSIDE THE GEAR AT THE END OF THE SHAFT GOING TO THE SWING ARM. I FOUND THAT SOMETIMES GREASE GETS INSIDE AND CAUSES THE SPRING TO SLIP INSTEAD OF GRIP LIKE IT SHOULD. IF YOU'RE VERY CAREFUL, YOU CAN TAKE OFF THE LEFT SIDE COVER AND LAY THE PRINTER ON ITS RIGHT SIDE (LEFT SIDE FACING UP). THEN REMOVE 3 OR 4 SCREWS AROUND THE GEAR ASSEMBLY AND LIFT THE ASSEMBLY STRAIGHT OFF THE PRINTER. TO GET TO THE SPRING CLUTCH, YOU'LL HAVE TO MOVE A COUPLE GEARS OUT OF THE WAY (REMEMBER HOW THEY GO BACK OR YOU'RE SCREWED - AND WATCH THE TONER ARM SPRING AS WELL). REMOVE THE PLASTIC C-CLIP ON THE END OF THE PICKUP SHAFT AND LIFT OFF THE CLUTCH GEAR. PULL THE GEAR APART AND WIPE OFF ANY GREASE FROM THE INNER SURFACES WHERE THE CLUTCH SPRING SITS. REVERSE YOUR STEPS TO PUT IT BACK TOGETHER.
--SORRY, MY CAPS LOCK DOESN"T WORK AND I DON'T FEEL LIKE HOLDING DOWN THE SHIFT KEY TO TYPE ALL DAY.
Aug 08, 2008 | Dell 1700n Laser Printer
X73 found loose spring
I was having a similar problem. After finding the service manual (4402_X73.pdf) and taking the thing apart, an ink-covered broken spring fell from the inside. I checked around the 'Maintenance Station' and found the other half still hanging. Apparently -because I haven't got a replacement yet to confirm- the spring goes across the bottom of the 'Maintenance Station' to a lever on the other side. If someone can tell me where to post a picture of the thing, I'll gladly do it.
Jun 21, 2008 | Lexmark X73 All-In-One InkJet Printer
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Dell 1710n Laser Printer Logo
41 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
