Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Squeaking noise while washing is going on. No noise at any other time. Repair man checked brake and said it was good. Any help would be wonderful as the noise is driving me crazy. Kenmore model number 1102970090,type 113-01, kenmore E12477. This is all the information that is on the lid.
  • mitji7476 Mar 04, 2009
    my washer is making very loud noise during finel spin and the noise is like when airplane is talking off.
    President:
  • 1,902 Answers
Have you or did the repair man check the belt to make sure it was still good and nothing was stretched? Also the motor to make sure that it was not causing this problem? And everything is oiled properly?
Posted on Feb 09, 2009
My 2003 Kawasaki ER-5 has a squeaking noise, sounds like it is coming from the front end when travelling at all speeds. The noise doesn't happen when I brake.
Hi, Chimmy I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Shifting Trans---CLUNK
7. Gears---WHINE
8. Front Forks---PLUNK
9. Rear Shocks---SQUEAK
10. Starters---CLICK
11. Solid Lifters---TICK
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Squeaking Sound from Front of Bike
Front End Squeaking
KAWASAKI ER 5 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-uncategorized-owners-manuals
Dec 28, 2016 | Motorcycles
Squeaking noise right front ?
not sure what type vehicle we're talking about here, although you can lube up the rack and pinion or grease up your upper, if so equipped, and lower ball joints.
Oct 06, 2017 | 2000 Jeep Grand Cherokee
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
Wheels squeak but stop when squeaking. Also ECM
the brake squeal sounds like you have calipers that need to be serviced...basically they need to be taken apart cleaned and lubed....as far as the ecm, with out the codes I cant give an acurate opinion...however if the list of codes is 10 or more long then the odds are goodyear is correct...check your local carquest or napa for the ecm...it may be cheaper for you...hope this helps
May 22, 2009 | 1996 Mercury Sable
84 Eldorado squeaks when driving and stops when i press thebrakes
shot in the dark but you may want to check your shocks
Apr 16, 2009 | 1984 Cadillac Eldorado
Squeaking noises
First check the brake pads , a worn out brake pads may create a squeaking and grinding noise, if its delayed then you need to change rotors the brakes,get check ....
Good luck...
Feb 03, 2009 | 1999 Ford Explorer
Squeaking noise Kenmore portable clothes washer
He checked the brake? i wonder why.... sounds like u need some grease on the agitator shaft or possibly something else.
Jan 04, 2009 | Kenmore 23822 Top Load Washer
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Loud squeaking brakes.
If they are wearing down, they may squeak, and some brakes have a metallic part that will come in contact with the rotor when the wear gets to a certian point making an awful squeaking sound telling you that mabe you should change 'em soon, eh
Jun 17, 2008 | 1995 Ford Escort
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
308 people viewed this question
Sal De
fordexpert
Robert Rankin
