Question about GE 36 in. Profile JP968 Electric Cooktop
GE Profile Gas cooktop stove- buzzer won't stop
Spilled water on stove-buzzer going off.
Shut off gas,unplugged electrical outlet & wiped up water but can't seem to get buzzer to stop when I plug electrical back in.
What do I do?
  • kandykain Feb 11, 2009
    Thank you! That is exactly what we've done and all is well again.
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Posted on Feb 11, 2009
GE PRIFILE STOVE TOP KEEPS CLICKING AND THE INGITE KEEP GOING OFF ON ALL 4 BURNERS...HOW DO I STOP IT FROM DOING THIS.
Hi pauliepaul22,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | GE Profile JGP636 Gas Cooktop
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
My ignition for the gas cooktop is clicking without being in the on positoin. will this be caused by cleaning with water? is it going to cause problems?
One of your burner ignition switches is fried. To see which one it is you remove a wire from each one till the ticking stops. Or plan be just unplug the stove and light it with a match.
Mar 12, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Electric starter won't stop clicking - how to unplug starter?
Your electric spark switches got wet. You may be able to remove the knobs and use a hair dryer through the switch/valve opening to dry them out.
Dec 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
I have a similar problem with my GE Profile stove
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
Aug 16, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
May 05, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
GE 36 in. Profile JP968 Electric Cooktop Logo
1,004 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
