Question about Bosch Axxis WTA 3510 Electric Dryer
How far should the dryer vent be from the wall to the dryer?
Our Bosch stackable dryer is supposed to fit in a space that is just large enough to house it. Will the dryer vent work properly if it is somewhat squooshed into the dryer?
    President:
  • 1,902 Answers
No, you do not want the dryer vent crushed at all. Go to Home Depot and find a 4 inch adjustable 90 or something along that line. The problem will be that your clothes will dry for alittle while and then you will stat noticing longer and longer dry times
Posted on Feb 09, 2009
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
How can i replace the back plate of my dryer with a flat one will not fit in space for hook up
Not likely such a thing. The funny shape probably has something to do with the air passages.
Mar 25, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Bathing suit lodged inside dryer vent chamber
Without actually seeing exactly where the item of clothing is lodged, this will be a tough problem to resolve. However, as a guess I will suggest the following:
Carefully pull your dryer away from the wall, far enough so you can get behind it. Be carefull not to stretch, pinch or damage your gas line. Next, with a screwdriver, unscrew the large vent clamp that attaches the aluminum vent to your dryer. Pull this vent pipe off the dryer inlet and see if you can access the lodged item. If not, you may have to attack the problem from within the dryer.
Feb 21, 2011 | LG DLG5988 Gas Dryer
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Can you stack if they weren't designed for it?
ive seen people build there own stack unit. alot of techs will tell you no but ive seen this done and there has been no issue. just make sure your platform is strong enough to handle the tumble of the dryer during normal operation
Jun 24, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
Dryer wont heat
Your Thermal Cut-Out (TCO) is blown. It should read close to 0 ohms if good. In addition, it is highly recommended that you replace the Hi-Limit Thermostat along with the TCO. These parts are commonly sold as a set. Failure to do so can result in premature failure of both parts.
BEFORE you replace anything make sure you check your dryer ventilation for clogs. Cleaning the lint screen is not enough as no lint screen captures 100 percent of the lint. Some lint always manages to end up in the vent line. This includes the blower fan housing INSIDE the dryer. Most dryer heat related problems are caused by clogged ventilation, leading to an overheat condition. In an overheat condition, the TCO will blow.
Some things to consider:
1. Are you pushing the dryer too far up against the wall? This lead to crushed or kinked dryer vent hoses which will result in overheating. Leave about a foot space between the back of the dryer and the wall to prevent this.
2. Does your dryer vent line run through an attic or crawl space? These types of configurations are notorious for creating choke points where lint can clog. This is either due to gravity in an attic configuration. Or, sags and kinks in a crawl space configuration. Frequent inspection and cleaning may be required.
3. Is your vent line excessively long? This can cause lint to back up because there isn't enough force from the blower fan to push it all out of the vent exhaust. The rule of thumb is: The SHORTER and STRAIGHTER a vent line, the BETTER.
I'm not trying to lecture you on something that may not be a problem with your dryer. I merely put this advice out as a precautionary to prevent you from purchasing parts, only to have them go bad prematurely because you weren't advised of what may be causing the problem. The TCO blows for a REASON. The reason is generally caused by an overheat condition. You need to figure out why.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 24, 2008 | Dryers
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Missing adapter to stackable whirlpool washer dryer front load
unclear as to the exact part your looking for, the dryer, should have a 4" hole out the back of the unit in which you install a standard 4"venting which is available a any large hardware/ home improvement store
Nov 15, 2008 | Whirlpool Washing Machines
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
488 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
