Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Printer doesn't work with refilled ink cartridges
I need a way to override the cartridge chip, or reset the printer to use the refilled chip. I have heard of disconneting and re-connecting the battery on some models but thought there might be an easier way.
  • 1 more comment
  • ric_myworld Feb 11, 2009
    my printer is an HP Officejet Pro L7580. The black, yellow and cyan refilled cartridges are working fine, but the magenta shows that it is empty. I have replace with three different refilled cartridges, and they all say, out of ink, not allowing my printer to print. I can replace with my original HP cartridge that shows empty, and it will still print. Thanks
  • live4weekenz Mar 08, 2009
    I have the same printer...HP L7580 and also replaced all 4 cartridges with refillable ones. All work fine except the magenta shows empty.
  • Al Klein
    Al Klein May 11, 2010
    Some printers just won't work with refilled cartriges, some can be reset with external "resetters", some can be reset by doing something in the printer. We'd have to know the make and exact model number of the printer.
Use the ciss system from jet or some other brand it work great i am using from last two tp three month.
Posted on Mar 15, 2009
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
I have a pixma mx870 and when I use aftermarket ink it keeps saying it cannot recognize the ink cartridge
There's a chip in the OEM cartridge. If the aftermarket one doesn't have the chip, or it wasn't reset, that's what will happen. You should be able to override this and tell it to use it anyway. Contact the seller or maker of your aftermarket cartridges for override assistance.
Be aware, however, that if you use an override, the printer will assume you're using a refilled or non-supported cartridge and burn through cleaning cycles and other ink wasting maneuvers.
The printer companies don't make money off these printers. They make it off the ink. So, they do everything they can to force you to use their highly profitable ink.
The Kodak all in one printers are actually very good, inexpensive, and the ink's dirt cheap, comparatively speaking. They're trying to change the model for printer companies, and making some headway.
Jul 07, 2011 | Canon Office Equipment & Supplies
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
Oct 21, 2009 | Office Equipment & Supplies
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to override printer for reset to use refilled ink cartridges.
you must be change printer cartridge
first time you try to clean cartridge OEM software some times you get successful
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Where is the reset button? I've refilled the cartridge and it still says it's empty (canon MP480)
this model uses a chip resetter avalible from most people who mfg. refill the brand & make of printer and see if you find a reset procedure. there are three different resets on cannon printers.if you do override it you will not be able to see the ink levels but if you reset the cartridge you will see all as a new cartridge.
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Without the make and model I can give you the following information: A print cartridge consists of the ink bellows or chambers, ink jets, which meter out ink in known dispensing rates, and a little chip that keeps track of the ink that is dispensed. Commercial refilling houses have the hardware and software to reset the little chips back to "full". And when you purchase that cartridge, it meters out ink from full to empty. There may be a utility in your printer control on your desktop to allow you to override and reset to full yourself. This is dependent upon what brand and model, and the software provided by the printer manufacturer.
Dec 14, 2008 | Office Equipment & Supplies
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
829 people viewed this question
Ben Johnson
