Question about Canon Rebel XT / EOS 350D Digital Camera
Canon 350d not turning on/screen not working/
Hey guys, I'm having a weird problem with my Canon 350d ... when I turn it on, sometimes the CF red light comes on and stays on, sometimes just the battery indicator LCD bit comes on, and sometimes it seems to work OK.
Whenever it works OK, I can focus and take a photo, but the CF light then stays on as if it is constantly trying to write the photo to the card.
I have tried removing the battery and the backup battery, and have checked the CF card (no photos are being written).  Any ideas, or do you think it's fecked?
  • 1 more comment
  • mail278 Feb 09, 2009
    I get a NO CF caption, but otherwise no difference.
  • mail278 Feb 10, 2009
    I am unable to get the screen to turn on (even in the menu functions) and hence I am unable to select shoot w/o card and take any photos.  On the relatively few occasions that the camera starts up, the autofocus works correctly, the shutter seems to be working OK, but then after releasing the shutter, the camera gets stuck with the CF light on, and the number of shots remaining flashing constantly.  I tried this yesterday and after about 2 hours the light was still on so I removed both batteries.
    I have tried formatting the card and even after getting stuck taking a photo, no data is written to it.
    Tried many lenses as well - EF and EF-S
Probably the CF pins are bent or broken
Posted on Mar 06, 2009
  • 38 Answers
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Posted on Feb 09, 2009
  • 1 more comment
  • thomtime
    thomtime Feb 09, 2009
    The NO CF caption is expected as the card is removed. What you need to test is if the camera powers on correctly and if the camera's shutter, auto focus etc.. is working reliably. Try tacking a few pictures without the card. Does the camera work from shot to shot? Are you able to see the brief preview that appears after each shot? I know nothing is recorded (no CF card) but this brief preview reads from the cameras internal buffer and should tell you if the camera is working.
    You may need to adjust the camera settings to shoot without a card. Set the camera to P mode (or any other creative zone) and go to the camera menu. Choose the forth menu tab (from left to right) and make sure “Shoot w/o card” is set to on in this menu.
  • thomtime
    thomtime Feb 10, 2009
    Well, we now know the problem is with the camera and not the card. Sounds like something is amiss with the camera's CF slot. It could be dirt or dust that got on the contacts or it could have been damaged if a card was loaded incorrectly or worse yet it may be an issue with the camera's sensor. You might want to try a different lens on the camera just to make sure it's not a lens issue but I suspect the problem is with the CF card slot. You will have to take it to a Canon service centre for a proper diagnostic and from there you can determine if the camera is worth repairing.
  • thomtime
    Sorry I can't offer a more hopeful conclusion.
Broken cf slot in canon 350d camera
CF pin assembly is soldered onto the main circuit board. Replacing this requires a soldering work station with a good heat gun
Mar 24, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not turn on
Try changing batteries is the first thing you should try, the memory card isn't really important if your Eos isn't working.
If your Eos works, try looking on the lcd screen. It should give you an error code. Go to canon's website into the camera section and look up the code.
If that doesn't fix the problem, if you are still under warranty, I would suggest you to contact Canon for fixing it. If your under warranty, it should be free. If your not under it, you might need to pay.
Sep 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
May 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Rebel won't turn on, red light next to "CF"
Assuming you have tried another card you know to be good...
Remove the memory card, main and backup battery, switch the camera on for 10 mins. While you are waiting look into the memory card slot with a torch and make sure none of the pins at the bottom are bent.
If there is this will mean opening the camera to straighten it or sending it in for repair.
If not refit backup battery and main battery and cross fingers..:)
best of luck
May 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
350D, focuses but won't take photo!
Does it do as you describe with a different lens? Have you ever had "error 99" or any other "error" show up in the upper LCD panel?
May 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
1,002 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
