Question about Amana AER5515QA Electric Kitchen Range
Electric range oven is spitting sparks
Pulled breaker. What next?
  • Anonymous Apr 14, 2009
    just picked up a used stove to replace teh faulty one we had. the new one spits sparks from the botom right. close to the power cord
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Check your ground wire. Where is the sparks coming from?
Amana Eletric Range, not working
check to see unisulated wires......but dont forget to turn the breakers off.by the way use electrical tape to insulate open wires.
Feb 05, 2014 | Amana AER5844VAB Electric Range
Oven not working
it is very likely that the element has failed internally and as such, the only cure is a new element.
Dec 08, 2012 | Kitchen Ranges
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Malfunction!!!!!!!!!
That poof that you heard was a shorted wire. More than likely you would not see it, but there is wires behind it.I would say you tripped a breaker or blew a fuse. Did you put the screw back in it that hold it in. If not turn off breaker before you do. Do you have breakers or fuses.
Nov 05, 2008 | Magic Chef CER3540 Electric Kitchen Range
Everything quit at once.
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. (Assuming your 50 Amp breaker for your range did not trip and you have power to everything else in your home) Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker
Aug 19, 2008 | GE Spectra JBP78 Electric Kitchen Range
Oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Jan 24, 2008 | KitchenAid KERC601 Electric Kitchen Range
Amana AER5515QA Electric Kitchen Range Logo
569 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
