Question about Kenmore 43042 Front Load Washer
Kenmore front loading commercial washer door will not opne
Don't know the model. the cycle ends, light goes out. Door is still locked. Happened twice. Anyone know how to open the door?
  • 417 Answers
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Posted on Feb 09, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ... > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
Sep 6, 2013 - Uploaded by
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer shows door not locked but the door is locked and will not unlock. it will not start either.
Try pressing 'end of cycle' for 3 seconds. You hear a click? Then wait for 2 minutes before trying the door, do not force door. No luck? Plug off the mains. Tilt machine backwards to unscrew 3 screws below the front panel, the kick panel. Slide the panel downwards & out.
Put your hand up towards the lock portion (inside the machine that is), you will feel a tear shaped thing, pull this thing a quarter of an inch down, the door will click open. Check to see that all wires are connected well.
Next try some WD40 on the door mechanism on machine, not on door, & try the door open/close a few times. Would be nice to know what service remember.(!)
Mar 09, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore washing maching door is not opening
Hold in "end of cycle" for 3 seconds. Or if you have a pic of a "key" on one of the buttons, hold that in till the lock signal goes off.
Feb 22, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
May 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Kenmore 43042 Front Load Washer Logo
77 people viewed this question
Sal De
 Brian Main
Brian Main
