Question about Select Brands Washing Machines
Miele novatronic w980 door wont open
After 30 wash refuses to open door when pushing the orange button also the button above pushes down with it ,this is the start button i think.i turned off at the mains ,waited switched on again it blew the fuse.put another in then pulled the machined tip it up and water came out .after this it released the door .please help professionals, im a ford mechanic so i will give it a service if im likley to strip it down. if you know wot wrong please share ur thoughts.thanks dully
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 16 Answers
SOURCE: Not working washing machine
Sounds like it's either in demo mode or you changed something when you went into programe mode. Handbook should tell you about how to get in and out of demo mode.
Posted on Feb 08, 2008
aborcass
  • 2651 Answers
SOURCE: Machine wont start
oohhhh. gwl10 os asearly as my knowledge about these machines go, placing a call to manufacture migh be helpfull . do any indicator lights blink when washer stops??? those are the codes so write down which ones are blink, if i had to guess though id lean toward an ou-of-balance switch failure. on my gwl10 thatslocatedunder console on right side, white bar hanging down measuring time tub hits into it. the switch usally corodes out. hope thats somthin anyway
Posted on Mar 01, 2008
SOURCE: Kenmore Oasis washer HE
How about the LD error message, I am Tried of having to bow out the drain hose
Posted on May 31, 2008
My miele t1430 dryer wont start when I press start there is one click and thd door opens
Seriously i'm not being funny, but are not pushing the door open button
Sep 18, 2014 | Dryers
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • Nov 09, 2012 | Washing Machines
    My Miele Novotronic W502 does not have any power although it is plugged in
    I would check that I do have power present at the outlet. If power is present the next step would be to check the fuse on the push button switch. Unplug the machine and then gain access to the push button switch by pulling the knob off after that you will need to take the orange plastic key from behind the detergent dispenser, and use it to remove the facia panel by pressing down slightly and wedging the key in between to gain access to the electronic. The electronic can be removed by taking out the 2 Torx 20 screws one on each side after that remove the connector plugs from the push button and unseat it from the clip. If you the fuse has continuity it could be a problem with the interference capacitor or the electronic.
    Feb 01, 2012 | Miele Washing Machines
    Liftmaster key pad opens door with a single number punch
    You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
    Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Washing Machines Logo
    Top Select Brands Washing Machines Experts
    Are you a Select Brands Washing Machine Expert? Answer questions, earn points and help others
