Question about Dell Computers & Internet
DELL --- Entrust/VPN - 1664
DELL Latitude machine. Using entrust and secure remote checkpoint vpn to connect to the firewall and then entrust provides the pass to get into the company network. My user is having a problem 1664 the directory is unavailable. The server is up and running so the directory is available. Logging in to the firewall server I can see that the user has managed to pass fine via VPN. Only Entrust seems unable to reach the directory. Any ideas?
  •  Orsolya
    Orsolya Feb 09, 2009
    Hello Wodan!
    Thank you! I just checked it and user had only udp encapsulation. As soon as I added IKE over TCP it worked!:D He is connected! Fixed the problem!
    Scholar:
  • 52 Answers
This is a known issue with Entrust, and normally happens if your communication via VPN is not using the IKE over TCP. Please select it. Also if necessary replace the ini file of Entrust, corruption of the ini file is known to cause the same error.
hope this helps if it does please rate it.
good luck
Posted on Feb 09, 2009
Speed test through the modem gives proper results. Connect a Fortinet 110c IPsec VPN and speed is tremendously slow
VPN connections are encrypted, this adds extra overhead to the connection and an extra place all data must route through.
Once connected to a VPN your speed is determined by the slowest connection between you and your end point (The site you're visiting, or the service you are using)
For example:
If your home / business connection is a 20mb but your VPN is a 1MB connection, then your speed is going to be less then 1mb once you connect through the VPN.
Encrypted traffic is usually a bit slower, however if you feel speeds are far slower then they should be, you will need to contact the vpn service provider and see if any settings in your VPN software can be changed to speed things up.
Dec 26, 2013 | Fortinet, Inc. FortiGate 110C (FG110CUS)...
While using checkpoint VPN-1 SecureClient to connect to Safe@Office 500 device in office mode, i can't connect to server at the office site. The office mode is on a different subnet than lan so my vpn...
In the rules, you will need to create a new rule that allows your VPN subnets access to you office LAN, and then on your office network gateway, add a route for your VPN subnet pointing back to your checkpoint firewall.
Nov 08, 2010 | Check Point Safe@Office 500 Router...
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
Aug 17, 2009 | 3Com OfficeConnect VPN Firewall - Firewall...
Sonicwall site2site vpn issues
please select nebios option in hq site tz190 firewall.
Apr 07, 2009 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Feb 18, 2009 | Dell PowerEdge 2600 Server
Site to site VPN between Checkpoint UTM 1 R62 and Cisco pix /Netscreen
I couple of points:
PIX has a few dislikes...
1. Pix does not like class A address, make sure you are using B or C.
2. The VPN subnet always has to be differant to the LAN.
3. Has to have a working DNS server.
4. Add static route, and last resort to main ethernet port that has the DNS & R62. (or 2 if on differant sub)
Hope this helps.
Dec 16, 2007 | WatchGuard Technologies Firebox X5000...
CANT GET VPN CONNECTION
the vpn connection from your home to work or the vpn connection from anywhere else to your home by vpn.
here you find a forum with the same problem:
http://broadband.motorola.com/consumers/support/faqs/surfboard_faq.asp#cant_login_vpn
Dec 07, 2007 | Arris SURFboard SBG900 (49402201900) Modem
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
279 people viewed this question
Alun Cox
