Question about Frigidaire FRS26RLECS Side by Side Refrigerator
Kenmore model 253 fridge cools then issues....
Hello, I have a Kenmore model 253 fridge that originally cools four about 5 to 6 hours, then the compressor just cycles on for approximately ten seconds and off for about two minutes and this cycle continues until the freezer is completely warm. If I unplug the unit and wait approximately 2-3 hours the process repeats itself. I've found the defrost timer functions as does the heating element. The coils never become more frosted than normal. I'm thinking it might possibly be the run capicitor, starter relay, or compressor. The compressor is warm to the touch, but certainly not hot enough to burn my hand. I'm at a loss and any help would be appreciated. The unit is only seven years old. Thanks
  • mclaneinc Feb 13, 2009
    I replaced both the relay and the run capacitor. I believe the relay definitely was bad. If I shook it, it would rattle. I plugged the fridge back in and it started fine. I waited until it had reached temperature and placed a cup of water in the freezer. It only froze a thin layer of ice over the top of the glass after sitting overnight. This morning I increased the temperature setting and the compressor would click on for about 5 seconds then off and this repeated about four times before the compressor finally started. I find it difficult to believe the brand new relay would be bad. I am going to check it again when I get home around 5:00 and if it's not working, trying jumping the thermostat wires to see if it kicks on. Any other suggestions would be appreciated. Thanks
    Problem Solver:
  • 9 Answers
IF, after replacing the Overload, and PTC (Run and Start Caps) on your compressor, and the behavior continues, . . you might want to see about replacing the Master Control Board, which is generally under the front grill. ONLY if the compressor kicks-off and doesn't start is that a symptom of the need for a new Overload and PTC. Otherwise . . . you have to replace the main Board instead!
Posted on Sep 16, 2012
    President:
  • 1,902 Answers
Ye, try to first replace the Relay, if that does not help then go to the run capacitor. Those are going to be your only 2 problems that you will have as long as the compressor is still doing its job by atleast running
Posted on Feb 09, 2009
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
My kenmore elite top freezer refrigerator (model 106.72999201) is only cooling the freezer not the refrigerator. Compressor is on. Help,
Switch off the fridge and after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The circulation fan must be checked to work as if frost forms it can be stuck up . So check if the defrost timer works and also if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
Jul 26, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hello! I have an old model Kenmore 21 CF. The fresh food part of the refrigerator (the freezer seems fine) is not cold enough. Last night at 11:30pm I turned it from setting 5 to 7 (9 being the coldest)....
Check to see if the fan in the freezer is running, without it you get no cooling in refrigerator. If that's ok check for ice buildup on back freezer wall if so you have a defrost problem
Jun 22, 2011 | Kenmore Top Freezer Refrigerator
Freezer working refrigerator not cold model# 253-74889401
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge cools for awhile then compressor cycles on and off
Not the compressor. Two reasons why. If your compressor was bad, you would not hear it at all, also the compressor would be very hot, do to the piston not moving and the shaft just moving or the liquid not turning into vapor. One way to check for sure is to take a multimeter and see your voltage. You can also touch the suction and the liquid line, if one is cold and the other is hot or warm then compressor is working ok. Also when you unplug the system and you reset everything, you are not reseting the compressor you are reset the relay
Feb 09, 2009 | Refrigerators
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frige not cold
check in the freezer back wall for frost might be defrost problem or if it has a thermistor it might not be working opening is your freezer 0 or below? 5 year warrant on compressor and sealed system read fine print on papaers if you still have them.may also be in defrost computer board if its a defrost problem
Sep 17, 2008 | Refrigerators
Frigidaire FRS26RLECS Side by Side Refrigerator Logo
301 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
