Question about Optics
Elevation won't go any higher
The scope is a Bausch & Lomb.
The number on the tube is AHO8044.
The rifle is a 60-06
  • 117 Answers
Take the rear ring off and put a shim UNDER the scope.A small piece of plastic from a blisterpack works well and is very stable.Cardboard or paper will swell with moisture and then shrink when it dries.Good Luck
Posted on Mar 25, 2009
Adjust the scope in the rings. Sometimes it requires a shim to solve.
Posted on Aug 23, 2009
Dirt inside my scope how to clean
If you mean dirt on the inside of the lenses like mould growing cheaper to buy a new scope or if flaking internals get a quote for repair
Oct 23, 2013 | Bausch and Lomb Bausch & Lomb Hunting...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
I have a Bausch & Lomb Trophy Riflescope Balvar Years ago it fogged up while hunting on a cold wet day. I sent the scope in for repairs and got it back, put it back on the rifle and about the third...
most things can be fixed again however at what cost???
the scope should be striped down and cleaned new "O" rings fitted to keep out the damp and then re-gased,,,,pricy job?
you could undo the small screw on the scope body and try warming the scope up to force out the damp air inside it then get some "NITROGEN gas" not co2! and blow that into the screw hole to push out any damp air left in it out and to re-gas the scope,,,,it may work it may not,,,,the nitrogen gas can be found at a camera shop check on the gas first but i think its called "dust away or dust off!" for blowing out camera bodys
dont start a gale inside your scope just jentely blow in the gas
Aug 30, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
I have an older Bausch and Lomb scope and have lost one of the screw on covers for the windage adjustment. where can i find a replacement
I have seen covers in the Midway catalog and Brownells, both have replacement covers and turret knobs. Hope this helps.
May 12, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Bosch & Lob elite ed foggy
Bushnell own bausch&lomb scopes and I have had good luck with there customer service. I would call them first .Just make sure you send a detailed letter with scope.Good luck
Feb 08, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Need manual for this scope
Bushnell owns bausch&lomb now they call it bushnell 4200elite scope I would call them for any info you need.
Jan 14, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
FOGGY SCOPE 4200 ELITE BAUSCH AND LOMB
the seals have leaked and some water has found its way into the scope,, it needs to be striped down and new seals fitted all the glass cleand and a regas,,, not cheep
Nov 12, 2009 | Bausch and Lomb Bausch & Lomb Hunting...
I just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
Oct 30, 2009 | Bausch and Lomb Bausch & Lomb Hunting...
RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Nov 18, 2008 | Bausch and Lomb Bausch & Lomb Hunting...
Optics Logo
359 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
