I have recently upgraded to win mobile 6 and everything is working great. The only problem that i seem to have is when i shut the phone down and turn it back on the home screen reverts to another home screen file.
The file it goes to is always the same. Is there a way to set a home screen file as default?
I have the exact same problem with my Dash. Did you find a way to fix it. Thanks. thomas_chapa@yahoo.com
Comment by Guest, posted on Mar 09, 2008
Every time you turn off the unit it will revert back to t-mobile default home screen .Can this problem be fix help
Best Solution
posted on Aug 01, 2007
Riddle - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
At 18 May 2007 10:00:09 -0700 Linley Meslier wrote:
He's not- from the description of the problem I assume he has a T-Mobile Dash which just had a WM6 upgrade ROM released.
His problem is a known bug with the upgrade- (one of three critical bugs! The others are that reminders are silenced forever if the "vibrate" profile is selected, and full screen media player videos play in the wrong orientation, IIRC.)
Work arounds for all three have been covered at xda-developers.com, and t- mobile.howardforums.com.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Problem with home screen on T-mo Dash:
Solution #2
Mini Me - usenet poster
I actually found the problem. Its an issue with the my5 favs module that t-mo uses. I found out how to correct it and also found loads of info now for the screens and plugin ids.
Solution #3
Melissa - usenet poster
The way I turn it off is hitting the power button on the side and choose power off. Also are there any help files about the xml coding for the home screen files? Ive been working it out little by little, but i cant seem to find the plugin ids.
