Question about SanDisk Sansa e250 MP3 Player
Sansa E250 model version
I'd like to try some upgrading (esp. firmware) to see if any issues can be solved that I've been experiencing with my Sansa. When I look at the back of the player, which has been suggested in other posts, there is no indication of which model version it is. How would I know? Does the e250 have a standard version? At least I believe its an e250. Since I do not have it with me at the moment it may not have the "e" in front of the 250...if that makes a difference. I've played around with this for at least 12 hours....can someone please help.
I have had several problems with my sansa, including doubling up of songs and Windows Media Player not showing my sansa media. If you'd like to address these two issues....please feel free. Any pointers there would also be greatly appreciated.
Thanks you SO much!
  • 8,596 Answers
When you go to the Sandisk website, look for the firmware under the Support --> Downloads section. The firmware you need is listed under Sansa e200 series - the Sandisk website is one of the only ones that I know about that gives a generic series number more often than an exact model number.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
Sansa e250
Substitute the REC button for the volume + button in the instructions below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 19, 2009 | SanDisk Sansa e250 MP3 Player
Trouble revealing & deleting sansa e250 mp3 player files
-Tha Mp3 Doctor
Dec 01, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player e250
-Tha Mp3 Doctor
Jul 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
First, the player has to be reset - see your manual for details
Second, if it freezes after reset, then your firmware has to be upgraded - the upgrade was at the Sandisk website, but I've heard rumors that they have taken it down - which will require you to make a phone call to Sandisk
-Tha Mp3 Doctor
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
All the music files seems to be deleted, Sansa e250 isn't resetting,..
Try the other recovery methods - a firmware upgrade MIGHT restore the player's native software.
-Tha Mp3 Doctor
Jun 14, 2008 | SanDisk Sansa e250 MP3 Player
E250 FROZE
-Tha Mp3 Doctor
Jun 05, 2008 | SanDisk Sansa e250 MP3 Player
Need help with recovery mode
Use voluem + method listed below:
-Tha Mp3 Doctor
May 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
I would recomemend that you upgrade the firmware on the device..that usually solve the problems you are having..Should you need assistance with the firmware upgrade, feel free to contact me..
I hope this helps
Please rate accordingly
Thank You
Computerrep
Mar 19, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
