Question about Lexmark X4550 InkJet Printer
Wifi signal is orange and blinking
Lost wifi connection
  • 1,602 Answers
NEED TO GO IN CONTROL PANAL LOOK IN NETWORKING AND SHARING, DEVICE MANAGER, CHECK ON SERUITYS AND FIREWALLAND IF YOU ARE ON A LABTOP IS TO CHECK THE SWITCH TO MAKE SURE THE WIFI IS WITCHED ON.
ROD
Posted on Feb 09, 2009
My wifi connection is good, but why is the wifi signal by the power button orange now previously it was blue? is this somthing i can manually fix? help
Orange indication means that the wifi is off or disabled. This will occur if:
1. You manually disable the wifi driver
2. You disable the wifi using the keyboard function key
3. You plug the PC into a wired network connection.
Check the keyboard hotkey for wifi and cycle it to see if for some reason the wifi was accidentally disconnected. If that is not the case, check the device manager to see of the wireless network driver is installed and working properly.
Dec 10, 2015 | Acer Aspire Computers & Internet
Epson L355 - My Printer suddenly cannot connect to Wifi network.
try to put it back to the same place where you took it, if it work, it means that the place where you moved it might have poor signal and if thats the case, i advise you to put a wifi repeater/extender near that wireless printer
Mar 05, 2014 | Epson Stylus Multifunction Inkjet Printer/...
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
ORANGE WIFI LIGHT IS ON
The orange WiFi light on the printer indicates that the printer is not connected to any network or trying to get connected to a wireless network when it's blinking.
Execute the Lexmark Wireless Setup Utility and make sure to enter the correct encryption keys if your wireless network is secured.
Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
Jul 26, 2011 | Lexmark X6570 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Blinking orange light where tghe wifi is
The light indicates that the printer's trying to connect to a wireless network. If the blinking wifi light has been going on for quite some time now but connection is still not going through, you will need to reset the printer's wireless network adapter. To reset the network adapter on Lexmark X6570, press Settings button > Network Setup > Wireless Setup > Reset Network Adapter to Factory Defaults. The wifi light will momentarily turn off then on and should be solid orange then. Try to reconnect the printer for wireless connection.
Jul 19, 2010 | Lexmark X6570 InkJet Printer
My dlink power indicator is orange and always blinking. Then, my wifi signal indicator light was gone!
The orange light indicates that there may be improper connectivity with the pc. Try to select proper ip address and try to ping the with it.
Apr 20, 2010 | Computers & Internet
Cannot connect to printer/scanner, blinking orange light and have lost wireless connection. Have already done all that was prompted (ie restart computer, shut down and unplug, moved the atena, refreshed...
Let me know the Operating system running on your PC.
Also check if the USB connector setting do something to run printers.
Regards,
Ellin Scott
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Loose connection with router
There must be something that has been introduced to your area that is causing distortion in your WiFi signal. 802.11 or WiFi is very susceptible to noise or signal distortion and can come from many things from interfering objects to other wireless signals such as Wireless phones. There are also many other things that can cause signal distortion I would look to see if you have added anything new around the time the unit lost signal. If your unit is working properly when you are closer to the router than this has to be the problem. Range is a big iffy factor when messing with WiFi.
Feb 26, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Lexmark X4550 InkJet Printer Logo
472 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
