Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer drum making noise
Whirlpool dryer Model #leq8858hq1 is making noise. I had turned the drum manually Did I cause a problem?
  • 2 more comments
  • fcmalia Feb 09, 2009
    can I have a solution
  • gregroll46 Mar 15, 2009
    I have the same problem with a loud grinding noise, have you gotten a solution?
  • Anonymous Mar 18, 2014
    dryer drum makes noise when it spins
  • Anonymous Mar 22, 2014
    Dryer will not spin makes a humming noise.
  • 1,031 Answers
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Posted on Feb 09, 2009
  • Whirlpool Master
  • 19,396 Answers
If the machine is making noise and not spinning, then the belt had slipped out, this is re routed by accessing the back of the dryer, and it is not a job that should be done by a home user.
if instead the appliance is making noise and spinning, that is probably a faulty drum bearing, or the drum spider (a lock at the back of the drum) that had gone out of place.
You can find all diagrams, and eventual replacements for your appliance here.
Lg dryer drum makes a scraping noise when turned on, what could it be?
The noise is caused by the drum support rollers that are faulty.
Please supply the machine model number.
Feb 13, 2016 | LG Dryers
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
Whirlpool gas dryer Model GGW9200LW0. drum will not start rotation, makes temporary hum noise. after turning the drum by hand a couple time i was able to get the dryer to work for about twenty minutes. but...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
May 12, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
1,876 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
