Question about Dell Inspiron 2500 Notebook
Hang at startup (BIOS)
Does a weak battery (depleted-needs to be replaced) can cause this kind of problem? Can laptops run without batteries? (AC Adapter only). After pressing the power button at startup, normally the Dell logo appears for a second (quiet booting) with the message below Press F2 to Enter Setup then continues to booth to windows(XP). But now, it hangs at the Dell Logo screen.The green light charging indicator turns orange and the blinking stops. All keys are dead.The fan won't stop. The only way to turn it off is to unplug the AC adaptor since my battery is already weak. I tried without the battery but the same thing happens. Some keys like F8, Enter, Arrow up key, etc..., when keeping it pressed while turning the pc on, will make a beeping sound. Different kind of beeps for a different key. But if there's a beep, there will be no display on screen. Screen will remain black, fan will stop after a few seconds with the charging indicator normal. And also, days before it happened, sometimes the right direction key seemed to be pressed or stuck and sometimes the shift key. So I turned on the filter keys to ignore repeated keystrokes. I also tried plugging another keyboard through USB and PS/2 port (laptop's keyboard disconnected), tried without the hard disk. Didn't solve the problem. Is it the SDRAM PC100? Can I test this with SDRAM PC133?
  • paintguy30 Mar 18, 2009
    same problem, when pushing power button it goes to the dell screen f2 button or any other button, no response, if I hold down the power button again it will shut off. booted fine 3 times prior but, did a windows update and was rebooting when it happened. 30 updates from xp service pack 2 to 3. but has to be a bios problem, i would love to know if there is a clear cmos jumper like a regular motherboard. does anyone know?
  • 479 Answers
Yes laptops can work without battery.
If the laptop is hanging on Dell logo and entering into BIOS then normally it is HDD issue but you have already checked without HDD so might be it is RAM or Board issue.
You can check with PC 133.
Please check your Laptop with minimal boot once (by removing all external hardwares like modem,tv tuner or graphics if any) and if you are geting the display one of the devices is causing the issue whch could be diagnosed by connecting one by one.
Posted on Feb 09, 2009
SOURCE:
It goes dark, shuts off constantly. Battery meter isn't showing charging.
Unplug the battery and plug in the AC power plug into the laptop;
Does the laptop start up and stay on?
If yes,
Then put the battery in WHILE IT IS ON; See if it starts charging.
If it does not; You have a bad battery and need to replace it.
If it does start charging here's what happend;
Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all.
The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in.
By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up.
If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue.
Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
Sep 30, 2013 | Toshiba Satellite L655-S5101 Laptop
My Studio XPS laptop does not stay powered without being plugged in. Replaced the power adapter in case it was not allowing the battery to charge. Ran dianostics on the battery and no problems with it. ...
Yes. If the battery is still ok and the ac adapter had been replaced, then it could already be a problem with the motherboard.
You may try to flash the BIOS of the motherboard first, here's the link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=STUDIOXPS13&os=WLH&osl=en&catid=&impid=
Select your operating system and download the driver under BIOS, saved on your computer and run it.
If that does not fix the problem, call Dell to have them check the motherboard.
Jan 05, 2011 | Dell Studio XPS 13 Laptop AC Power Adapter...
Insert battery hang not working
have you tried using an extra battery? or remove and put back in the battery? if it still wont work, try updating your BIOS, check your website if they have one available.
Apr 03, 2010 | Acer Aspire 5050-3242 Notebook
Battery light blinks, but it won't turn on
Take out the battery and only hook up the AC Adapter. If the laptop turns on then that means the battery is weak or bad and needs to be charged up if its weak, if its bad, replace it.
If you hook up the ac adapter without the battery hooked up and you don't get any power, try another ac adapter and if you still don't have power then that means the motherboard is bad.
Jan 01, 2010 | Toshiba Satellite M305D Notebook
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
Battery only charges upto 7%
Chances are the battery itself has been damaged. These batteries have several cells linked together, and if any of the cells fail then capacity drops accordingly. You may want to look to replacing the battery.
Aug 28, 2009 | Dell Inspiron 6400 Notebook
My Compaq NC6400 is very slow and doesnt charge the battery
i had the same prob and changed the ac and its bac to its old self
Jul 11, 2009 | Computers & Internet
Laptop hang problem
Could be a bad battery. Try running it on AC with the battery removed. If it works, you might need a new battery.
If that doesn't work, sounds like dust and dirt has clogged the inside which causes it to overheat and shutdown. Someone will need to take it apart and clean it.
Jan 15, 2009 | Acer Aspire 5315 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Open Questions:
See all Dell Inspiron 2500 Notebook Questions
Dell Inspiron 2500 Notebook Logo
369 people viewed this question
Ekse
Clive
Clive
