Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I mistakenly over scrubbed the base of my gas oven can I
Resurface this oven???? My foil sticks, and I think I ruined the oven........... What can I do?????
    Brigadier General:
  • 3,614 Answers
How large of foil stick on the oven..?
Posted on Feb 09, 2009
  • 1 more comment
  • micromaster
    micromaster Feb 09, 2009
    also,
    • may i know the exact unit that you have.
    • the size of foil stick to it
    • and the cause why it stick on the surface.
  • micromaster
    you can do scrubbing on the stick foil.
    better to remove the area which the foil stick, then scrub it/
    NOTE: do not use a self cleaning feature on your oven! this will damage the unit.
  • micromaster
    after such scrubbing, and paint / coating can be also removed.
    • in this case all you have to do is paint. using a metallic base spray paint will do
  • 679 Answers
Please explain in details.
I melted a plastic bowl in oven I scraped most of it out while it was hot but now I have thin spots of plastic film, I need to know how to clean without ruining the surface of my oven cavity
Warm the oven to 100c allow to cool for 15 mins with door open then lightly scrub with a ball of aluminium foil this won't scratch ad foil is softer than the oven lining
Jan 06, 2018 | Ovens
How can I clean burned tin foil from the bottom of my gas range
You may have to scrub it off using something that will not destroy the bottom material.
Sep 16, 2016 | Samsung FX510BGS 30" Freestanding Gas...
Mistakenly placed foil on bottom of oven. Pulled out foil and noticed minor damage to lining. What is the impact of this and does it need to repaired or replaced
Other than the appearance of the bottom liner I don't think you did any other damage. You probably just melted some of the foil to the liner. Just keep and eye on it the next few times you bake something. If for some reason the liner coating starts to come off more every time you use the oven---then it probably will need fixed. This would require replacing the complete oven liner if the bottom is not removable as a single part.
Jun 14, 2015 | Frigidaire 30" Built-In Double Electric...
Tin foil was melted to the top of one of my wife's and my electric stove burner coils. I was able to remove most of the foil but there is still some stuck to the burner and will not come off from scraping...
Use a fine grit sandpaper. Don't scrub too hard, you may scrub through the heating element. Take it slow and easy -- may take a while.
Charlie
Feb 05, 2011 | Microwave Ovens
My wife put foil (alum)on bottom of new oven , foil melted in and ruined finish ... im over that , now she wants to know if its dangerous to eat food cooked in said oven
i would say you are ok,but the thing that consernes me is what was the temp that melted the foil in the first place,its takes a lot of temp to melt foil and i mean over 800 degree,was this over a long period?yes it is safe to eat the food but get that oven checked?rate this answer.adrian,,,,,,,,,,,,
Aug 22, 2010 | Ovens
I used aluminum foil in the base of the oven, the foil is stock in their, i need to know how to get it out.
From everything I have read, you probably used non-stick aluminum foil which has a light teflon coating. The coating melts and ahderes to the oven surface at temperatures 350F and greater.
Many people have had the same problem. The closest to a solution I could find was in a forum where the user says...
"I did the same thing last night and freaked because the oven is only about a month old. I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible
Turn oven on to 200 lay an old wet bath towel on top
Use a plastic spatular to remove the foil
They said it will take sometime to remove the foil, in some cases
days, and that you can still use the oven but DO NOT use the self
cleaning untill all the foil is removed."
Unfortunately, several people reported they were never able to remove the foil. Best of luck.
Aug 11, 2009 | Frigidare FED300E Electric Range
Melted Tin Foil in bottom of oven
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Bosch range model #hes236
there is no easy answer to this except elbow grease. however, i often put aluminium foil on base of oven with no problem. did you leave it there during self-clean when temp is very high?
Mar 29, 2007 | Bosch HES436U Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
