Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
70,000 BTU Ready Heater
I
have changed the ignitor, the pump, and set pressure at 4.7. Unit comes on fuel sprays, but will not fire.
  • culligan20 Feb 26, 2009
    heater runs fires shuts off does several other things fuel pressure5 psi.
  • 232 Answers
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Posted on Feb 11, 2009
To Justaskjoe, I have put in all new filters, new pump vanes and cleaned everything real good. I put new hoses on incase there was a leak. Cleaned photo eye and even tried a new one. I have fuel spray coming out the front, plenty of spark on the plug, new fuel. I and several others are at a lost here.
Posted on Jan 21, 2010
  • jeffbrooksr Jan 15, 2011
    I had basically the same problem, and after cleaning the fuel pump and installing the proper
    tank hose, I discovered the vanes in the pump where installed backwards that kept it from running properly. After inserting the vanes properly it rns like a champ.
  • Jerry Horner Jan 16, 2011
    I found out that it was the cup in the nozzle. Took it out, didn't look bad, but turned it around and ran fine. Bought a new nozzle to have on hand if it quits again down the road.
I HAVE A 115,000 btu Keroscene heater. It just stopped running.
Take the top cover off of the unit. Plug it in and look inside the burner can to see if the ignitor is glowing. If not you probably need an ignitor. You can remove it to check the heating element to see if it is intact, but be very careful, it is more fragile than glass. If it is intact, you may have a control board issue. The ignitor should glow before the fan starts. Be careful to stay away from the fan blades while doing this. If the ignitor glows, and the motor starts, you should then be able to see fuel spraying out of the spray nozzle. You may need a flash light. If the fuel does not spray out of the nozzle in the correct amount, the unit will shut down. There is a photo cell that detects ignition. If the fuel pattern does not look even, you could have low air pressure out of the pump, a dirty fuel nozzle, or a plugged fuel screen inside of the tank. The air pressure comes from a pump on the back side of the blower motor. Insure that the filter are clean on the pump; there are three of them, and the plastic end cap needs to come off to access them. If they are dirty, they need to be replaced. The air pressure off of this pump is very critical to proper fuel delivery. The rated output pressure of the pump is on the heater data plate. You will need a low pressure air gage to check this pressure. Another source of low air pressure is the plastic end cover over the filters. They tend to crack with age. Spray soapy water on the end cap while the blower is running to look for leaks.
Jan 18, 2011 | Reddy Heating & Cooling
Wont fire after following start instructions
OK-- Let's go thru your trouble shooting steps, and what you found:
1.) Fuel: Sufficient, and right type?
2.) Has the unit fired and run before?-- What is different in sounds, or settings now?
3.) How does this unit ignite the fuel?-- With Spark, or with Glowing ignitor?
If Spark-- can you hear it sparking?
If Glowing ignitor, -- can you see the glowing? (in a darkened room..)
4.) Can you see that Kerosene is spraying at the nozzle?-- is the pattern correct?
5.) Have you check fuel and air pressure settings-- according to the manual?
After observing these details-- let us know what other clues you are observing now.
I'll be here to take you to the next step, if you like--- Just add your new comments in the 'respond' box-- they will send them to me for further follow-up.
Mack B
Jan 17, 2011 | Mr. Heater Portable Kerosene Heater -...
Problem: Will not spray fuel through nozze. Lines are not clogged. Have cheecked spark plug. It is firing. Special note: It is Series 35,000 Reddy Heater.
You can try adjusting the pump pressures, but it does sound more like the pump went out on you. Have you checked to see that the shaft to the pump is turning? I am not sure how that mates up with the motor be it a set screw, or coupling, but would check it over the pumps are generally not an issue.
Dec 20, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Dayton 70,000 btu kerosene heater only runs consistently with 3/4 of a tank of fuel or more. Once it is below 3/4 it keeps shutting off. I have cleaned filters, tried to set pressure but pressure won't go...
If you can only get 4 psi from the pump then you have a problem with the rotor. This could be from the vanes not coming out properly of if you have replaced or serviced the rotor you may not have the clearance set properly between the pump ring and the top of the rotor.
Make sure to inspect the pump cover for any small cracks..
If you pump pressure in not enough the unit will not be able to pull fuel from the tank and you will see the burner cone slowly start to go from the orange color to a dark color and the unit will shut down.
Feb 10, 2010 | Dayton (3E386) Heater
Not getting fuel after air and fuel filter maintenance.
If the maintenance procedure included anything that required you to dis-assemble the air pump then you must simply re-set the pump pressure in order for fuel to be pumped into the combustion chamber. . It's an easy procedure. Instructions for setting the pump pressure
Feb 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
100,000 btu therm controled heater
What did you set the air pump pressure at? This is critical on heaters with Hot Surface Technology. Setting the pump pressure is always the FIRST place to start troubleshooting on these heaters.
Here are some things that can prevent ignition even though there is fuel & glow:
  1. wrong air pump pressure
  2. the nozzle is restricted & distorted not allowing fuel to contact the glowing ignitor
  3. the nozzle is worn. It should produce a cone of fog, not a spray.
  4. there is water in the tank below the fuel.
Oct 23, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
848 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
