The battery cover on my PhotoPC 550 has just broken one of it's flimsy 'hinges'. It snapped while I was loading some rechargeable batteries, which I noticed where a tighter fit than the standard AA batteries they were replacing. I have two brands of rechargeables, and both are longer than the standard AAs, enough to put too much pressure on the feeble battery cover. End result is that I can't put batteries in the camera anymore. I'll try an epoxy glue repair but I'm not optimistic.
1. Can anyone else confirm that rechargeables are longer, or have I just got some weird ones? 2. Any suggestions on how to get the camera working again? Do Epson sell spare parts for this model?
Thanks, John
John Laidler | | (+612) 9519 3912 68 Applebee St. St Peters N.S.W. 2044 Australia <URL:#>
Aren't you using the Epson brand rechargables? The manual specifically states that these are the only ones to be used in the camera. I've found Epson to be a very easy company to deal with, kinda like Olympus used to be. I'm confident that if you adjust your attitude about 6 degrees to the left and contact Epson they will make everything right at little or no cost to you the valued customer. I don't think I'd mention cramming the wrong batteries into the camera though... Health and Peace, Mahesh Maharishi Yashica (a satisfiedPhotoPC600 user) >
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Epson PhotoPC 550: rechargeable batteries have ruined my camera:
Solution #2
posted on Aug 01, 2007
Riddle - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I have a Minlta Dimage V and use rechargable NiCad's but found the bump on the positive terminal was too flat to make contact and had to add a solder blob to the end of each battery. That probably does make it a bit longer but they still fit, there is quite a bit of play with the spring used.
Solution #3
Pasty - usenet poster
I guess you got the weird ones. I just compared my rechargeables to normal AA batteries, and seemed like the rechargeables were even a very slightly shorter than standards.
I were more conserned about the voltage of those - rechargeables are 1.2V and standards 1.5V. But I have understood that this isn't problem either, as long as the difference is not really "big" or then the voltage is higher than normal.
HK
