Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
JVC big screen t.v.
Green color is bowing down from the top of screen and is going straight across the bottom Hitachi 43FDX20B RPTV...I have a convergence problem, words, etc not exactly in focus, 3-D like effect... How difficult is it to remove the circuit board to replace the chips/resistors? Any chances of getting shocked? Thanks!
  • 42 Answers
Not that bad to remove
As long as it is unpluged you won't get shocked
Look to the right of the boards Remove all the little screws from the convergence board
Make sure you mark or notate where the correctors go
Flip up the little connectors to the left of the board
Do not force the board up if you have to force it you missed a screw
use solder wick and remove the parts
make sure there are no shorts and you replace all the resistors in the kit
Good luck
Posted on Feb 09, 2009
Thee green on my Hitachi 43fdx20b has gone wacky, ive seen an answer to if the red and blue go wierd but not the green. What can I do to save my t.v.?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2011 | Hitachi 43FDX20B 43" Rear Projection...
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
We have a Hitachi 53udx10b tv. Recently it was
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Dec 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My tv has a bow in it every time a banner comes across
It is not unusual in these sets for things not to be perfectly straight---if the set has recently been repaired for a Convergence problem--someone may not have adjusted it correctly.
Understand: if it is a 43uwx10b Hitachi:
The green convergence is adjusted first for a grid of straight lines up and down and left/right---if the green grid is not straight you are going to see a bow when things scroll across the screen.
The other possible problem you may have is a convergence problem--if you go into the customer menu and try to adjust convergence--not the magic focus-- are the blue and red adjusting or not?
I know the HItachi sets very well--I own two of them and have repaired hundreds of them.
Let me know if you have more information or need advice--I am here to help people.
If this has helped you rate this solution as I do this here for free.
REGARDS, SD TECH
Nov 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Hitachi 50FX20B 50" Rear Projection...
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
I think its called a convergance problem. or maybe color alignmen
Hitachi convergence amps - It sounds like you are pretty proficient in repair - here is the potential fix and parts needed for the repair - Hitachi uses Convergence Amplifiers
http://www.hometheatershack.com/forums/service-support/5600-crt-based-rptv-convergence-repairs-post43743.html#post43743
Dec 19, 2008 | Hitachi 43FDX20B 43" Rear Projection...
JVC big screen t.v.
convergence fail. replace convergence ICs with stk-392-110 can be accessed through the front. take off the speaker grill and panel behind that. there will be a large heat-sink under the picture tubes that is the convergence power board. disconnect all cables(mark any that look the same) going to and from that board de-solder the amps --- replace any burnt or open resistors--- plug everything back in turn the tv on and adjust any alignment needed in the regular tv menu.
Feb 20, 2008 | Televison & Video
Hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
