Question about Hotpoint Dishwashers
DISHWASHER FDW60P HOTPOINT , FAILS TO DISPENSE DETERGENT TABLET , FRONT DISPLAY FLASHS FAST AND PREWASH INDICATORS
  • 2 more comments
  • ken_marchant Feb 09, 2009
    all outlets are free from blockage !
    dishwasher has no draw , it has a latch on a flip door to dispense detergent , this is not opening .
    If i take tablet out of dispenser and leave door of dispenser open , place detergent tablet manually then start cycle , machine runs ok !
    I think it could well be a problem with the dispenser , thank you for your input .
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for this problem may be due
to the thermostat.If there is any problem
in it,it will show these types of problems.
so check the thermostat once.
try this out..
thank u..
Posted on Feb 09, 2009
  • Hariharanath V Feb 09, 2009
    hi..then make sure that your belt is working
    properly.Even if your belt is bad u will come
    across this problem.
    check it out..
    thanks..
  • 257 Answers
Hi, The blinking lights are usually an indication of a problem. Your manual will tell you what the blinking sequence means. If you have had a power blink or such the failure mode can be reset. Press and hold the start button for 30 seconds, if this doesn't work the electronics can be cold rebooted by turning off the circuit breaker for 30 seconds. If it is a hard electronic failure it will resume blinking the failure codes. Good Luck!
  • Hotpoint Master
  • 19,396 Answers
Check if you are getting water into the dispenser.
If water regularly flows to the dispenser, and only softener is not dispensed, then the lid located at the back of dispenser, that moves from detergent to softener dispenser is stuck.
The dispenser drawer must be taken apart to fix the problem, you may need to call a technician.
  • 1 more comment
  • Ginko
    Ginko Feb 09, 2009
    If there is water, and the dispenser lines are not clogged, then you have a defective dispenser mechanism.
    Here is the replacement part.
  • Ginko
    Ginko Feb 09, 2009
    I did not talk about "draw" I told you that the dispenser lid is probably stuck inside because of a broken mechanic, that is same latch you are talking about, you need to replace the assembly that costs $35.
    First you need to test that there is voltage to the dispenser using a multimeter. Remember that there is AC power in your appliance, and if you DIY you must observe strictly all safety rules.
    Here is UK replacement:replacement part.
    Alternatively enter your model number (the one in service tag) here.
    If you cannot find model number see: help finding the model number on your appliance.
    I will be grateful if you can correct the negative rating given.
    Thanks.
  • Ginko
    Ginko Feb 09, 2009
    Re: "If i take tablet out of dispenser and leave door of dispenser open ,
    place detergent tablet manually then start cycle , machine runs ok !"
    In this case you need to test voltages to dispenser from control board.
    If voltages read fine it is still a faulty dispenser assembly, that gets stuck when door is closed.
    Check that water is flowing under all conditions, otherwise it is just a hose problem.
    I do not have schematics for this particular model , but that is the way it works. You can post here model number , I can see if I find diagrams.
    Often on repairs you have to work eliminating all possible cause, then you replace the defective part.
  • 679 Answers
It seems some chock in the outflow of water.check that.
  • rockfixya
    rockfixya Feb 09, 2009
    If your dishwasher is cleaning poorly, check these:
    Water-inlet valve
    Internal filters
    Drain valve
    Spray arms
    Water temperature
    Detergent cup
    let me know for further assistance.
    Thanks
  • rockfixya
    When the detergent cup doesn't open, check these:
    Timer
    Bi-metal switch or wax motor
    Detergent cup, itself
    please do some more comment for further assistance.
    Brigadier General:
  • 3,614 Answers
have you check the water supply coming into the unit.?
try to reset the unit, turn the circuit breaker off for a while, then back on.
let me know
  • 1 more comment
  • micromaster
    micromaster Feb 09, 2009
    . If
    the dispenser is not opening, first make sure you aren't loading the
    machine so dishes or pots and pans are touching the dispenser, and that
    dish racks aren't blocking the dispenser. Also check to make sure the
    dispenser tray isn't cracked.
  • micromaster
    check it and make sure that there was no blockage on the dispencer.
  • micromaster
    so it is possible that there must be a stuck object on that area..
    let me know if you noticed a crack or a some stuck part on it.
    double check
    Genius:
  • 1,913 Answers
Check your fuse conductor that it works or not.u have to check it.alsao check your power supply and earhing properly.
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
Need to remove panel to access spring on detergent dispenser lid on hotpoint dishwasher
is several screws on front door (inside side), take them out carfuly, because is where the door spring is connected, and you must reach on the detergent dispenser mecanism.
Nov 06, 2010 | Hotpoint Dishwashers
Delicate light flashing will not dry
Post more information about your problem if you need more help....
Good Luck!!
Thanks
Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Machine do not take detergent from the dispenser at all
that sounds to me like a water pressure problem. check the hoses aren't kinked and that water comes out at a reasonable rate.
the small filters where they attach to the machine may be limescaled up and want cleaning.
Feb 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Hotpoint Aquarius DWF50 Dishwasher, cycle not starting getting flashing ECO/Fast lights, any ideas?
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Jul 05, 2008 | Dishwashers
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
20 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
