Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Have a 70,000btu ready heater. changed ignitor & pump set press.
Still will not run. starts runs for about5-10 sec,
    Scholar:
  • 50 Answers
If it shuts off it may be a problem with the thermocouple which needs to reach a certain temp so that the heater knows it is lit to continue sending fuel and air. If this is not operating propoerly it can cause the problem you are describing. You can check if this is the case by testing for continuity across the disconnected thermocouple leads while holding a lighter on the thermocouple. At room temp you should not have continuity, when it heats up the circuit should close. If this is not happening it may be bad. You can further test (CAREFULLY) by jumping the thermocouple leads where they come back to the control board. If it continues to run that is your problem. Also make sure the thermocouple is aligned properly to get heated by the initial heat or it will never warm up enough to close the circuit and allow the heater to continue to run...
Hope that helps...
Posted on Feb 09, 2009
Ready Heater 60 wont start. Fan runs for about 5 seconds and then stops.
Check the wires for good connections. If the connections are good, then check the adjustment for the ignitor (sparker or glowplug).
Feb 10, 2011 | Reddy Heater 60,000 BTU Kerosene...
Hi i have a master space heater model 150 paraffin, runs ok with the cover off but when i put the cover back on it stops. The flame out button clicks to shut the heater down. any info please
These units have a air pump on the back of the fan motor. Has anyone messed with the settings? The pump usually runs off of 5 to 6 lbs. of pump pressure. This is what controls the fuel flow that is sprayed out of the fuel injector. This unit also should have a photo eye for flame out control. It is positioned near the ignitor looking though a hole in the combustion chamber. Make sure it is clean and looking in the hole. Make sure your ignitor is working also.
Dec 01, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
H100id induced pool heater runs for 4 minutes then stops heating
I just solved this about an hour ago. It's the connection from the circuit board to the ignitor. The same thing happened to me that it ran a long time and then it wouldn't. At some point it loses spark. The large wire from the board to thee= ignitor is the culprit. Take the ignitor out and press the two electrodes to about 1/4"-3/8max. Clean the surface plate where it meets the heater and also clean the brass piece on the othe end. Then clean the brass piece on the circuit board. Slide the 2 boots down a little and expose the receptacles. Press them a little with pliers, put them on their respective connections and then slide the boots back on. It started right up and has been running since! This after I bought a new gas valve $178! Let me know if this does it for you.
Jul 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Sealy space heater,shuts down
the motor is going bad. I would like to help you more but really the only thing you can do is replace it and your problem will be solved.
Feb 08, 2009 | Reddy Heater-30-55,000 BTU Variable
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
All Pro 200t Will not ignite
John- the ignitor does not stay on for the duration of the running time. It only stays on for the first 5 seconds. This is long enough for the flame to ignite and perpetuate itself, assuming the fuel delivery system is up-to-par. The photocell monitors the flame color and if the flame becomes off-color then the photocell tells the control board to shut the unit down. Naturally, too rich or too lean affects flame color.
Now, I'm confused by your description "the heater cycles 3 times". Tell me more.
I'm glad to see that you checked the pump pressure. Have you used soapy water to check for air leaks all the way to the nozzle? A leak in the airline, fuel line, or a crack in the nozzle adapter will cause no fuel delivery, or reduced fuel delivery as well as reduced atomization of the fuel - all of which can cause a lack of combustion. A restricted fuel filter will cause starvation.
Eliminate all possibilities of a fuel delivery problem before you start blaming electronics because there is not much way to test the board or the photocell successfully without DESA's diagnostic tool. Unfortunately, replacement of the componants is cheaper than the tool.
Dec 17, 2008 | Desa International RH125AT Utility Heater
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
422 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
