Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Powder drawer wont open
Cant get the powder drawer to open and the water is coming out all over the floor when I try to turn it on
  • Anonymous Mar 24, 2014
    during rinse and sping
  • Hotpoint Master
  • 3,463 Answers
Grasp the drawer firmly, and pull out until it reaches its stop, then press the plastic lever down in the middle of the drawer at the rear, and pull the drawer out.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
Tip
Dishwasher does not dispense cleaning tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
Washer doesn't dispense fabric softener
This can be either one of the solenoids in the dispenser has failed, the timer is not sending the signal to let the softener in, or the water is not circulating through the dispenser to flush it through. The water hose to the dispenser will occasionally plug up. Check the hose first, it's the cheapest to unplug it. ;-) Oh, I have seen the wires to the solenoids just simply come unplugged too.
Jan 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Ive just brought a re-conditioned bosch classixx washing machine,
boil wash the machine with old towels and powder, 90 degree wash will bring out the bleach in the powder and the old towels will throw the bleach around the tub removing the bacteria that has grown in the tub, the bacteria comes from the washing powder to eat the dirt in clothes and sometimes gets left in the tub and pipes (most people only wash at 40 degrees the bleach wont come out the powder until at least 60 degrees hence the build up and smell). you may have to do this twice to get it smelling good, remove the drawer also and clean off any bacteria with a cloth and spray bleach.
Jul 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Excel 1200 water coming out of power drawer
try cleaning the filter located at the bottom of the machine in a small access door
Mar 01, 2009 | Washing Machines
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
