Question about Kenmore 54701 Dehumidifier
What is the proper humidity control % setting?
Comfort-Aire 50 pint dehumidifier
  • 1,902 Answers
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
Posted on Feb 09, 2009
My Comfort-Aire BHD 651-C died
The Comfort-Aire crapped out again! We started the season with a little 17-pint Sears, but it wasn't cutting the mustard getting the accumulated moisture out of the cellar, so we fired up the Comfort-Aire 65-pint machine. It got the humidity down to 50% pronto, and kept it there for the better part of a week when all of a sudden it quit. Died! Nothing! Not a glimmer in the control panel, and pushing the buttons did absolutely nothing. Unplugging it and plugging it in again produced a faint "chirp" but that was all. Naturally, the thing is weeks out of warranty. Without the warranty, the nearest service place wants a $60 "consultation fee" just to look at it, so I decided to see if I could fix it myself before seeking professional aid.
After getting an exploaded view of the machine from the web, I removed the collection bucket, the filter, and the two screws from under the plastic front cover. In addition to the two screws, the cover is held by little tabs that fit into notches in the steel sides. To get the plastic cover off, I slid a wooden popsicle stick under the plastic, thus stretching the plastic enough to get the tabs out of their holes without scratchng the unit.
The front cover is tethered to the unit by a cable attached to a circuit board which forms the back of the push-button control panel. On one side of this circuit board there is a row of 14 soldered connections. They are very close together, and any conductive contaminent that gathers between them is guaranteed to short them out. That's apparently what happened to mine, for scraping between them with a toothpick, and cleaning them with a toothbrush
brought the unit back to life again. That's all it took to repair my Comfort-Aire. The plastic cover snaps back
in place easily.
on Jun 09, 2008 | Comfort-Aire BHD-651 Dehumidifier
Bought a new BHD-651-G 65 pint dehumidifier. Set it up and started it. Immediately got an error code "AS"" which is a "humidity sensor error." The instruction book said pull the...
It's easy to replace, if after you dismantle the unit, you know what to look for. If not, than it would be difficult. Your Owner's Manual may have a schematic in it, that would be of tremendous help. If it doesn't contact Heat Controller Inc, and ask them to email you a schematic. Then, after reviewing it, you can decide whether it would be to difficult or not for you to do.
Jul 18, 2011 | Comfort-Aire HD-651 Dehumidifier
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 09, 2010 | Comfort-Aire BHD-301 Dehumidifier
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I...
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
May 03, 2010 | Comfort-Aire HD-651 Dehumidifier
Comfort-aire dehumidifier 501 cycles on and off
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Jun 28, 2008 | Comfort-Aire Dehumidifiers
Kenmore 54701 Dehumidifier Logo
542 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
