Question about Asko T701 Electric Dryer
T721 overheated because of broken belt and pulley fixed that but unit will not turn on now. where are fuses or reset.
  • adam239 Feb 09, 2009
    do not see any fuse holder or reset please discribe exactly where it is and how I release fuse
    Master:
  • 848 Answers
Hi
first check the circuit breaker........The fuseswill be on the back right top.
Posted on Feb 09, 2009
  • gopinath pasupathy Feb 10, 2009
    it will be grey flat head cover that you twist 1/4 turn to remove......
How come my aquabot turbo will not move or pump water?
Probably the drive belt came off the pulley or the belt broke. Similiar to a vaccuum
May 27, 2014 | Aquabot Turbo Robotic Pool Cleaner
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
Bangs and sqeels during high spin cycle, also there are plastic shavings in sink
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem causing banging. Unplug the unit and pull the unit out from the wall disconnection the water hoses after turning of the water. Remove the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broken you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. If you turn the pulley by hand you should not hear scraping. If you do in could be the bearings or a screw is rubbing against the shell. If you have to replace the outer tub shell (approximately $300.00 for parts only). I would unbolt the bolts holding the shell and find where the tub or screw is rubbing so you do not have to replace the expensive shell.
Feb 23, 2011 | Frigidaire ATF6000ES Front Load Washer
It sounds like the spring in my washer has broken. It made a loud sound during a cycle and now the basket is completely off balance and barely moves. I was wondering if the spring is worth fixing or if...
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem. Pull the unit out from the wall and removed the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broke you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. The belt is easily replaced once you know the below procedure:
1. Place the belt around the center of the motor pulley stretching the belt to the spider pulley leaving no slack in the belt.
2. Keeping the slack out of the belt, place the belt on the outside rim of the spider pulley as much as the belt tension will allow you to do so.
3. Keep the tension on the belt and slowly rotate the spider pulley counter clockwise until the belt is completely on the spider pulley.
Rotate the spider pulley several times to make sure the belt stays in the center of the spider pulley. If the belt is not centered after several revolutions you need to remove the belt and reinstall it after moving the ribs of the belt on the motor pulley in the direction which centers the belt. If it was my unit I would fix it unless you have to replace the outer tub shell (approximately $300.00 for parts only).
Feb 18, 2011 | Stainless WSXH208AWW GE Extra-Large...
Power steering went out on a 2002 trailblazer. the serpentine belt was slipping off so I replaced the serpentine belt and pulley tensioner, still out. Pulled the steering pump, pulley shaft was broken....
Have you checked your tie rods? Possibility one is either bent or broken, I've seen it before on TB's. That pulley shaft is a common problem to break, especially when cold out. PS pumps/pulley shafts and tie rods will snap if doing donuts in the snow with the steering wheel cranked, or off-roading. The PS is completely mechanical, no fuses or relays.
Jan 31, 2011 | 2002 Chevrolet TrailBlazer
Asko T721 dryer. Support rollers started to fall to bits (dryer making bumping sound as it rotated) so I bought a new set and replaced them. Not a single electrical connection was removed bar the door...
  • If you took the drum out and took the belt off you may have put the belt on wrong as there is a switch under the drive or idler pulley that must be pushed on from the pressure of the belt on the pulley. Also go and make sure both breakers are ok in the breaker box as it runs on a 220 volt sys. and if one is tripped this type of thing can occur.
  • Good luck and please rate me if this helped! thanks again for choosing fixya
Oct 12, 2010 | Asko T721 Electric Dryer
My dryer is not as hot and taking much longer to dry the clothes. How do I fix this. I clean the lint trap after every load. I have a ge profile dryer about 5-6 years old.
Three main possibilities:
Either lint is clogging the airflow or a fuse is popped from overheating, or the heating element is broken..
You have to open up and clean out no matter what.
Unplug the unit.
Remove the lint screen and the two screws at the lint slide.
Use a putty knife to release and pry up the clips which hold down the top cover, tilt up the top cover.
Remove the two screws near the top which secure the front cover, tilt out and lift off of the two clips at bottom.
Release the belt tensioner and remove the drum.
Now you can completely vacuum out the entire cabinet. I know some persons who take a pressure washer to it (the motor seems to tolerate the wet treatment).
Remove the rear cover by removing the screws.
On the left (as you look at the rear) you will see a duct leading to the lint screen. Remove the screws and wiring harness (mark the wires). Lift it away and you will see the blower fan. It is invariably loaded with crud, coins, paperclips etc. Clean it out. If you must remove it turn it clockwise as a wrench holds the motor shaft stationary (there is a flat spot near the belt pulley).
Check the heating element. It should not be broken and read "closed" on an ohmmeter.
Clean all and reassemble after you have replaced any fuses.
Fuses should read "closed" or zero ohms. Some person test for bad fuses by temporarily connecting the two wires and then running the unit. If it only gets hot when you do this you should DEFINITELY replace the fuse.
Aug 02, 2009 | GE Dryers
Overheating
I assume you are talking about a Northstar. Could be a lot of things. Start with the coolant level. Another easy step is to check the coolant pump belt. It is located at the top of the motor (driver's side front). It is under a belt guard next to the valve cover. You can see and feel the belt under the cover without removing anything. The belt is only about 1/4" wide and is driven by a pulley off the overhead cam. You can see the tension pulley as well. My problem was a broken belt and an easy fix.
Nov 02, 2008 | 1997 Cadillac Seville
Asko T701 Electric Dryer Logo
16 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
