Question about Samsung CLP-500 Laser Printer
Error Jam0 in tray1
I had a paper jam and cleared it. Now every time I power my CLP 500 on I get the message Jam0 in tray1. I have checked and can find no jam.
Help
  • John Robertson May 09, 2009
    Identical. "Dr Printer" software simply tells me that the driver is out of date, even when re-installed; it doesn't tell me what "Jam0" means.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
  • 1,602 Answers
GO ON LINE TYPE IN MANUFACTURE NAME,MODEL#, ERROR MESSAGE AND ENTER KEY LIKE THIS:
CAMSUNG CLP-500 LAZER PRINTER ERROR MESSAGE JAM0
ENTER
ROD
Posted on Feb 09, 2009
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Clp-510 constantly gives paper jam error, although none exists.
false error message / could be due to the dirty rollers or bac=d sensors on the printer. Sometime when printer does not get enough power it might give this erropr message .
Hence also try to change the power source.
Oct 16, 2010 | Samsung CLP-510 Laser Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Jun 02, 2008 | Office Equipment & Supplies
Samsung ClP-500 install cyann toner
Please take your unit to an Authorized Service Center ASAP. Do not tur on the unit again. That burned fuse means that the temperature sensors inside the printer (thermistors) are not working correctly and the unit is overheating.
Oct 23, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
405 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
