Question about Briggs & Stratton 15,000 Watt Home Standby Generator
No charging voltage to battery
Model 01815 12Kw Briggs & Stratton Generator. Battery not being "trickle" charged from CMA pcb. PCB pn 191652GS.
If the battery is charged from a external charger the generator will do a manual start and auto start/test, but due to loss of standby charge the battery will run down in several weeks. The sense transformer has the correct voltage to the CMA pcb but output on terminal 12 listed on the unit schematic as power +12vdc at all times. The CMA board also has two test plugs listed as JTAG and RS232 but no info in the service manual as to the devise needed to test from these plugs. Is there a way to confirm pcb failure before purchasing a new pcb?
    Problem Solver:
  • 5 Answers
Funny, My father who lives 300 miles from me, has a 7kw unit that, hasn't worked right since it was installed 5 years ago.Has had the sevice techs there so much,now they won't even come out anymore.I work in power generation for a power co. After trouble shooting over the phone with the old man,looks like the same problem.Low bat volts.
Posted on Aug 01, 2009
    President:
  • 1,714 Answers
You can test the charger right at the battery. With the system just sitting in regular stand-by mode. If you lift the battery leads, they should have about 13.5 volts coming in from the trickle charger. If there is no voltage there, it can't charge. It would be a bad trickle charger.
Posted on Jul 04, 2009
Battery does not charge
Check all the battery connections, if they look good replace the battery.
Nov 19, 2013 | Briggs & Stratton Garden
Does not Charge Battery
time to change charging system under fly wheel
did you have to jump this mower and use a car battery of high boost charger ? if so you burned out system
Battery light on but battery ok
A battery light being on does not necessarily mean the battery is bad. It usually means that the tractor is using more voltage than the alternator or generator can supply. You need to have someone test the output of the voltage regulator. I am guessing that the alternator is not charging the system. If you don't correct it, then the battery will go dead.
Dec 21, 2010 | Briggs & Stratton Garden
Have a 22 ohv B&S els 725 v twin want recharge a new battery
If you want to recharge a "new" battery you should use a trickle charger and leave it on over night. Remove the ground side wire from the battery before charging. let us know
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a model 5251 generator that was not charging the battery. Now the motor will not start.
either a)there is no battery charger installed, or b)the battery charger is installed incorrectly, or not hooked up at all. the third possibility would be that the charger itself is not operating correctly but in my experience that is seldom the case.
the charger uses source voltage from the utility to charge the battery between tests and usage. the generator does NOT charge the battery during operation, so a trickle charger that uses source voltage must be installed in order to keep the battery charged. this tends to slightly decrease battery life.
reconditioning the battery prior to re-installation after the charger has been sorted out is recommended, but a new battery may still be needed at this point.
Oct 26, 2009 | Generac Electrical Supplies
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 15,000 Watt Home Standby Generator Logo
802 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
