My van was running fine then boom in the drivethru it just shut off i replaced the fuel filter thinking it was not getting fuel but it is had it towed home pulled a spark plug wire turned it over and no spark i check the power wire going into the distributor with the key on and its not getting power plz help
Hi orvil brad hear I would check the ing. fuses you have at least one and maby two in the inside cab fuse block, and also one or two in the engine bay fuse panel, there is also a relay located in the eng. bay panel, also you may check the ing. wire that goes to the coil system, This wire will have no 12volts until the ing. switch is turned on then it will show 12volts. It has a habit of coming loose at the coil sometimes. Good luck
SOURCE: 98 Astro Van,when warm hesitating, stalling
WELL YOU CHANGED ALMOST EVERY THING EXCEPT IGNITION CONTROL MODULE........
SOURCE: 2000 chevy venture doesnt start
Not the IAC, or MAF, or 02
Does the Van Crank over?
Have you checked the IGN Relays? 1,2,and 3?
How did the Battery test out?
Anything below 11.9v battery is dead.
So I suggest that you do not throw any more parts and check the battery again.
SOURCE: My 1990 Chevy Silverado with a 5.7 L engine quit
check if you have fuel pressure you probally shorted out the fuel pump fuse. like i did when i changed out my fuel pump. if you changed your cap rotor plugs and wires it is probally not that.
SOURCE: fuel pump wiring diagram for 1998 chevy express
Well if theres power going to the relay but not out, then you need a new relay. If theres power in and out of the relay, you might need a new fuel pump. The electric fuel pumps inside the tank are actually lubricated by the fuel as it pumps it, and if it runs dry long enough, it can burn out the pump
