Question about Philips Business 170B 17" Flat Panel LCD Monitor
Volume Control Bar does not go away
When I use my Philips 170B 17" Lcd Monitor I cannot get the volume bar to go away , it stays on screen premanentally. Aggh!! Please help!!
  • Anonymous Feb 14, 2009
    volume bars still on monitor scren
  • 1,602 Answers
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
ROD
Posted on Feb 09, 2009
I have a Philips 170B7 monitor. The volume adjustment bar always appears in my screen. It's very disturbing. The volume also ups and downs automatically. How can i remove this problem? [ I have cleaned the...
I had this exact problem with a Philips 170B. I thought there was dust/bugs in there and tried blowing them out, to no avail. Eventually, I decided I had nothing to lose - I dug in and see what was going on.
  1. There are three screws:
    • one each side, on the back toward the bottom
    • you also have to take off the stand - it has four bolts, accessible behind a plastic cowl - just pull the cowling off.
    • now you can get to the third screw - it's behind the stand. I didn't see it at first :'
  2. Pull up the two tabs on the bottom of the display, and ease your way all the way around the whole bezel with a spatula or something. Take your time.
  3. You can now get to the circuit board with the buttons on it. I unplugged the leads, the two screws, and eased it up off the two little pegs that locate it under the bezel.
  4. The volume buttons are labeled "left' and "right". I levered them little fellas up and yanked them off with me pliers :)
  5. While this worked for me, be prepared to DESTROY YOUR MONITOR - I certainly was. However, I am delighted that I no longer have to go out and replace it with 24" of full HD beauty :/
http://imgur.com/hVg1r.jpg
http://imgur.com/RxnNM.jpg
http://imgur.com/yJOHP.jpg
Aug 14, 2010 | Philips Business 170B 17" Flat Panel LCD...
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
Cannot get volume to turn on.
First try using MP3 player or any audio source to feed the monitor audio input jack (green jack) to see if you get the sound OK. Just need to narrow down the problem. The DC adapter for the sound bar is OK?
Apr 07, 2010 | Dell E173FP 17" LCD Monitor
Volume bar won't go away
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
How on earth do I control the volume on a Dell E172FPB monitor?!!
What dell model is it. Most did not have speakers built in. There are clips to install an optional speaker bar on most dell monitors. But it has its own bolume control.
May 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Sound indicator
you can find it in control panel option.do this-
  1. click on start button on task bar
  2. click on settings option
  3. click on control panel option
  4. in control panel click on (sounds and audio devices) option.
  5. and click on place volume icon in the task bar.thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 24, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
Computer says disk boot failure when I turn it on.
hard drive failed or you have a cd in or floppy in the drive.
Jan 07, 2008 | Philips 170B5CB 17" LCD Monitor
Philips 170B lcd monitor
Crackling sounds are probably due to a couple of capacitors failing due to age, on the control board. (They can also "whine"). Should be easily replaceable by any experienced technician. Not a difficult job.
Nov 21, 2007 | Philips 170B4MG 17" LCD Monitor
Philips Business 170B 17" Flat Panel LCD Monitor Logo
1,355 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
