Question about Panasonic DP-C354 Copier
ERROR CODE E07-21 on Panasonic DP-C354 copier
Can I fix this myself? The copier message says call engineer.
  • ltaghi Feb 10, 2009
    Copier Engineer came and fixed.
    It would appear that the output tray on the document handling part had dropped down and for some reason had not lifted up again.
    If he removed the document handling part the copier became functional again.
    He lifted the tray back up and copier all OK again.
    He said the problem may have occurred because we may have switched copier off and on again quickly when trying to resolve the paper jam problem. I don't recall that we did but am pleased that problem now resolved and copier working again.
    Thanks for your assistance guys!
  • 679 Answers
Yes. unplug the copier for a long time. and check again.
Posted on Feb 09, 2009
  • rockfixya
    rockfixya Feb 09, 2009
    Or try a reset......
    Remove back panel and look for a round battery (disk ) remove for 30 Sec. turn on & off , and then replace battery. that will reset your copier.
    Thanks
  • 916 Answers
Error eo7-21 is usually associated with a drive bar motor problem. You are going to need to call a service technician to get this problem resolved.
    Brigadier General:
  • 3,614 Answers
It means, that the machine need to call service maintenance. you better contact the model manufacturer regarding on this
  • micromaster
    micromaster Feb 09, 2009
    if you have no idea, or a professional background for servicing a copier, its better to call a service engineer, to avoid further damages on the unit.,
On a panasonic dp-c354 is there a way to wash the waste toner container
you can dump these then blow them out with air but if they become to aged it is just best to replace the waste container
May 06, 2014 | Panasonic DP-C354 Copier
Panasonic D-P C354 error code E04-14
try function, original size keys and number 3. Function should appear
Mar 19, 2012 | Panasonic DP-C354 Copier
I have error code E03-30 on panasonic DP C354,how i can fix and reset?
You most likely have a bad feed motor. It's located mid right rear behind big PC board and mounting plate. It's a job for a technician.
Jun 23, 2011 | Panasonic DP-C354 Copier
I AM FORGOT MY Panasonic DP-C354 Copier PASSOWORD CAN YOU HELP ME?
1. Press the "Function", "Copy", and "3" keys simultaneously in that order to enter the Service Mode.
2. “Input the password” to enter the Service Mode (default password is 00000000, except for C322/
C262 which do not require a password).
3. Press "7", and then “Start” keys to enter the F7 Service Mode (counter ).
4. Check the entry for the option 01 that will be you password
Jun 19, 2010 | Panasonic DP-C354 Copier
Can i change the DQ-UHS30 drum unit into DP-C354 copier myself or do i need a technician to do this
Most Likely a Tech.
Order your drum unit from PrecisionRoller.com then look at it to see if you can do it yourself. I'm a Canon guy but I think that on this machine it's not to bad. Open your front door on the machine and look it over. There may be some plugs to unplug etc.
Jun 09, 2010 | Panasonic DP-C354 Copier
My dpc356 scanner error 716 comes up once document scanned
incorrect smtp server address is set. these error messages are very accurate. check all ip address settings, ip address, subnet mask and gateway as well as smtp.
Apr 15, 2010 | Panasonic DP-C354 Copier
How do I cancel a print job - Panasonic DP-C354?
Go to controll panel touch the print button on the left bottom, touch print queue, it will ask for password which is 8 zeros. touch print job and hit cancel
Sep 27, 2009 | Panasonic DP-C354 Copier
Error Code E07-27 How can I fix it myself ???
That error is a finisher tray lift error. If you do not see anything binding the trays, service will have to be called or finisher disconnected. Pay attention to the screws, they can loosen causing the trays to bind.
May 11, 2009 | Panasonic Workio DP-3520 Copier
Mac Drivers
you need to have a PS [post script] key installed in the machine before you can do anything
Jun 13, 2008 | Panasonic DP-C354 Copier
Panasonic DP-C354 Copier Logo
357 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
