Question about Optoma DX605 Multimedia Projector
Optoma DX605R blows bulbs/ ballast problem?
Where can i get a balast for optoma projectors? I replaced bulb an after 20 minutes the bulb exploded. i am now down $550 in bulbs. a repair tecnician told me it was a ballast problem?
  • 1602 Answers
SOURCE: No Power
IF HTE UNIT WAS WORKING FINE, THE BULD MAY OF NOT BEEN BURNED OUT THE SENCERS FOR THE BULB MAY HAVE BURT OUT GIVING YOU A FUALTY BULB ISSSUE,
DOES THE FAN RUN, PUT THE OLF BULB BACK IN AND CHECK WHAT IS WORKING AND NOT WORKING AND COMPARE IT WITH THE NEW BULB IN AND THAN CALL THE MANUFACTURE AND TALK WITH TECHNICAIL SUPPORT PERSONNEL
ROD
Posted on Feb 03, 2009
webkruzer1
  • 17 Answers
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Posted on Apr 09, 2009
projdoc
  • 2237 Answers
SOURCE: My Optoma projector has the red light come on for
if it is a replacement lamp, was the lamp timer reset after replacement? if it's the original lamp and the projector only has 83 hours on it, there is either a bad lamp or a cooling problem.
Posted on Aug 10, 2009
SOURCE: OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Posted on Mar 29, 2010
fathitkf
  • 1871 Answers
SOURCE: My Optoma HD72 projector operates for about 1
That must be an overheating problem . If you are sure that you replaced the bulb correctly , then i would say that one of these parts [ Power transformer , or Fuse , or the whole Power PCB ] is hurt .
please rate !
Posted on Apr 12, 2010
Testimonial: "Thank you very much!"
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Optoma PK301 lost a color
it is not correlated with bulb
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Optoma PK301 PICO Pocket Projector...
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
Jun 25, 2013 | Optoma HD70 DLP Projector
Bulb blows on gt700
Possibly a bad ballast or power supply going to it causing it to either kill the bulb or your old bulb may still be good. Did you rest the counter in the menu for the bulb life after replacing?
Nov 05, 2012 | Optoma GT700 Projector
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
OPTOMA HD 70
You didn't include much information other than the lamp not coming on. Here are a few things to try, if you haven't already. Unplug the projector and allow it to sit for a minute or two. Try removing/re-installing the lamp assembly. Sometimes especially after a lamp change the bulb/contacts are not properly seated. Ensure the screws are securely fastened to keep the bulb seated. Are there any lights, i.e. power, bulb or fan errors lit? I've had my HD70 since 2006 and use it everyday for my main television. PS3, DVDs and Cable all run through it. I average one bulb per year and about 3100 hrs on each bulb. My last bulb actually lasted 3600. I have tried all the above and each has worked at some point. Hopefully you can have some success.
Jul 04, 2009 | Optoma HD70 DLP Projector
Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
May 10, 2009 | Optoma HD72 Multimedia Projector
Optoma ep795 projector won't power up after lamp replacement
did you replace the lamp because of this issue? if so, the ballast may be bad on this unit
Jan 07, 2009 | Optoma EP759 - HDTV Compatible DLP...
Optoma DX605 Multimedia Projector Logo
379 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
