Question about Dakota Heating & Cooling
1998 dodge dakoata pickup [heater] has 195 degree thermastat [new
At operating temp. when turned on,everything works fine. after a moment or so.It will blow cold air.It will do the same when turned off and on again.
    President:
  • 2,559 Answers
Change the thermostat,It sounds like it is staying closed to long.
Please rate this a fixya
Posted on Feb 09, 2009
Operating temp
The thermostat opens at 195 degrees and the radiator fan comes on around 220 degrees. So normal range is between these two temps.
Jul 01, 2013 | 1998 Cadillac DeVille
Dakota v6 has new heater core, thermostate, can hear blend door opening, and upper hose and both core hoses are hot but still no heat. dummy temp gauge looks like it might be reaching 160 range instead of...
160 degrees should be hot enough to get some heat.
You could check the engine temp with a scanner to confirm.
I would double check the blend doors, and the temp of the coolant in and out of the heater core. I use an inferred temp gun.
Oct 08, 2012 | 1995 Dodge Dakota
Which thermostat do I purchase for my 1994 Dodge Stealth (automatic SOHC)? Choices are Beck/Arnley 170 Degrees F, Stant 170 Degrees F, Stant 180 Degrees F, Stant 195 Degrees F.
either of these manufactures are good just install one with the manufactures recommended temperature rating,as the wrong temp range can change how the car will run.example gas mileage,running temperature,cooling fan operation etc.
May 01, 2011 | 1994 Dodge Stealth
Where is heater control valve on 2003 dodge ram pick up
THERE IS NO HEATER CONTROL VALVE ON THE WATER HOSES. NEW HEATER CORE. INLET LINE right before heater core hot, outlet after core look warm. Burped cooling system 5 times with engine at operating temp. Installed homade burp VALVE right after heater core outlet(high part of hose). Still no heat. Removed water pump, impeller still in good shape not stripped off shaft. Removed heater core hoses flushed water thrue the connections on the block to the water pump INLET and outlet. flushed water thrue heater core and hoses. Going to put it back togeter today. Used known good gauge to check water temp for operating temp in test. 195 f
Oct 22, 2010 | 1997 Dodge Ram 1500 Club Cab
My heater is blowing out cold air, i changed the thermistate and had it if flused out. The hot water from the heater core is going in but not coming back out.
Yeah you probley have air in the coolent system try letting it run untill the temp is about 195 degrees and then cut it off lwt the water **** down and out mor in and do it over untill you got heat
Jan 09, 2010 | 1998 Chevrolet S-10 Pickup
97 chevy pickup running temp
That's not really that unusual of a temp. 195-210 is a normal range. If you'd like, you may try installing a 195 degree t'stat. As well, make sure your cooling system, (radiator, heater hoses, and water passages in the block) are in good order. If this engine previously used the "orange" GM coolant, they were bad to clog up hoses and passages. I had to take all my hoses off, as well as water pump and thermostat and run pressure hose through all the orifices to get the gunk out.
May 18, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
1998 Dodge Durango no heat when using heater.
BLEND DOOR STUCK OR BROKEN. NEEDS TO REMOVE DASH AND HEATER/EVAP CORE BOS TO REPAIR REPLACE.
Jan 08, 2009 | 1993 GMC Safari
1994 pontiac firebird HAS NO HEAT
Okay. warm up vehicle, get radiator hoses hot.  Turn on heater, fan on low.  Grip both rubber heater hoses close to the firewall, from the engine compartment side.  They should be too hot to hold for long.  If they are not hot, then you have a lack of coolant circulation to the heater hoses.  If they are hot then access heater core, behind glove box area.  Blend door which moves as you chose HOT or Cold, should be cable controlled, move the controls and be sure the door is actually moving. Keep me posted
Dec 17, 2008 | 1994 Pontiac Firebird
Heating & Cooling Logo
42 people viewed this question
Top Dakota Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Dakota Heating and Cooling Expert? Answer questions, earn points and help others
