Question about Breadman TR444 Bread Maker
Clamps that hold the pan in place don't hold.
Hi, the little metal side clamps that hold the pan in place are not strong enough and the pan comes out and clunks around - - Not the recipe because I have used it several times before.  Where can I buy new metal brakets/clamp?
  • 134 Answers
Hi you need to go here for spares
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Posted on Feb 14, 2009
How to change a 2003 x-type jaguar head light bulb
Open your hood.Behind the head lamps you will see black plastic covers held with spring clamps. There is one on each side of the assembly (the outer clamps not visible). So reach in and undo the clamps to remove the covers. Disconnect the wire on the headlamp bulb and release the small spring clamps on each side of the bulb. It should come right out. Install the new H1 bulbs and make sure the dimple goes inside the little alignment hole in the housing for alingment. Slight twisting L & R will help you check this until you feel it insert) Install the small clamps. Install the connecting lead wire on the bulbs and install the covers. Make sure to place BOTH clamps on the covers. NOTE: the passenger side is really limited in room to remove the outer clamp. I recomend a long screwdriver to help release it. Re clamping the outer clamp will take some finesing to get a hold of it and bring it forward. I recomend looping a metal wire on the middle to help bring it out and pull it to clamp it.)
Dec 12, 2010 | 2003 Jaguar X-Type
My heater is not working what do i need to replace??
First check blower motor, possible go to bad or no power to it check fuses blower switch blower motor.
Try this procedure to remove this device...
1 Detach the negative and positive battery cables from the battery of your 2001 Jeep Cherokee with an open end wrench and crescent wrench.
2 Remove the cap from off the radiator and also from the top of the coolant overflow tank on the passenger side of the Jeep. Locate the drain valve at the base of the radiator and place a drain pan on the ground, below the drain valve.
3 Open the drain valve on the radiator with an open end wrench and allow the coolant to drain into the pan completely. When it is finished, close the drain valve and remove the drain pan.
4 Unfasten the dash pad on the top of the dashboard by using a screwdriver to undo the screws holding it in place. Check the defroster vent and remove any screws holding the vent screen in place.
5 Remove the trim panel underneath the passenger side of the dashboard with a screwdriver and set it aside. Locate the plastic box that is sitting underneath the dashboard on the passenger side.
6 Undo all the screws that are holding the plastic box in place with a screwdriver and set the box off to the side. Locate the heater core that was sitting inside the plastic box.
7 Unscrew all the screws that are holding the heater core to the firewall with clamps underneath the dashboard. Remove the clamps from the heater core.
8 Lay a piece of plastic sheeting on the passenger side floorboard to cover the carpet from any coolant remaining in the heater core. Pull the heater core away from the firewall until you see the hoses attached to the inlet and outlet pipes on the unit.
9 Remove the water hoses from the pipes on the heater core by unscrewing the hose clamps with a screwdriver and sliding the hoses off the pipes.
10 Take the old heater core out of the Jeep Cherokee and dispose of the unit. Recycle the drained coolant by taking the drain pan with the fluid to your local recycling center or automotive supply
Keep us updated.
Dec 02, 2010 | 2001 Jeep Grand Cherokee
How do you change out a heater hose elbow in a 2005 buick lacrosse
cool car down and drain the radiator, usually a spigot or valve at the bottom. remove the clips or clamps holding the hose on, pull hose off. get a new hose from any parts store, sometime helps to have the old one with you. install new one, put on new clamps and tighten firmly, pour in new coolant. check your owners manual to see what kind of coolant Buick recommends.
Oct 04, 2010 | 2005 Buick LaCrosse
Someone stole my brake lamp relay out of my fuse box and when they did the little clamps that hold the relay in and make it connect came out with it. What would those little metal pieces be called
Not sure about any clamps that hold the relay in place. On the bottom of the relay are blades(part of the relay) for the connection. They fit into a LUGS that are crimped onto the wires that the relay connects to. To get a replacement lug you need to know the dimensions for the blade it connects to(Thickness and width, usually 4.8 x 0.8mm, just take the relay) and the diameter of the wire(cut a small piece off if you have enough slack). To replace you need a specialised crinping tool although a pair of pliers can also be used but then soldering is definately recommended. Your local electrical supplier should stock it and theyre like $5 for 100.
Hope it helps.
Jun 28, 2010 | 2006 GMC Yukon Denali
How hard to change oil cooling hoses on 2003 gmc 2500hd pickup
Hard and PITA!!!! If your hose is leaking from the factory compression clamp from the metal oil to the rubber lines, you can carefully cut the old factory compression clamps off and replace them with new compression clamps. Make sure you use compression clamps and not hose clamps, the hose clamps are not good enough and will fail causing you more work if not a motor. This will only take you about 30 min to replace the clamps on the motor side and 30 min on the oil filter remote side. Much easier then replacing the whole unit and disconnecting the engine mount to raise the engine enough to snake the old line out and snake the new line in place since the housing is connected to the ends of the lines and there is no room to get the lines between the engine and frame with out lifting the engine about 3 inches.
Thank you for using Fixya and good luck
Mar 25, 2010 | GMC Sierra 2500HD Cars & Trucks
Our 2000 gmc 2500 7.4 engine the antifreeze runs between the valve cover and the intake cannot find where fluide come from, check hose fitting, help
hello, i had a 1997 chevy dually, had same problem, the way gm changed their clamps for hoses, now the clamps sorta hold their self, there made of plastic, and they slip into each other, they are like male and female connections, they slip into each other, i would check all radatior hoses, heater core hoses, i had 6.5 turbo diesel, great motor, only thing is the clamps for heater hoses was plastic, just like on the rocker arms, on the 6.5 they have a nylon plug that holds rocker arms in place, keeps them moving from side to side, they have to be changed at least, 150,000, mine broke off, had to replace 2 pistons, pushrod came out went into motor and broke the skirts off two pistons, very expensive, i would check all clamps with the plastic male to female, ends, maybe that will help, also check thurmostat cover, been known to leak a little too.
Feb 01, 2010 | 2000 GMC Sierra
98 Ford Escort (Mk6) Power Steering Cooling Tube Clamps
well to do it right u should replace the hose
Jan 28, 2010 | 1995 Ford Escort
DVD drawer will not open lite on LVC-9016
I had this problem, and found that the cause was that the mechanism that lowers the disk spindle to allow the drawer to open was not strong enough to overcome the magnet that clamps the spindle into position when it it is closed. The following procedure fixed the problem:
Unplug the unit, and remove its outer cover (eight screws, four on the sides and four on the back)
Remove the thin metal cover over the DVD drive (four screws)
There is a round metal cover on the top of the drive. It is glued in place. Carefully pry it loose. Be careful not to bend it.
The spindle clamp assembly is beneath this cover. It consists of a plastic housing and a metal insert that holds a black fabric gasket and a small, donut-shaped magnet. Remove the entire assembly.
The metal insert is held inside the plastic housing by three bayonet-style prongs. Rotate the insert to free it, then remove it.
Remove the black fabric gasket and the magnet from the metal insert.
Here's where it gets a little strange. The problem is that the magnet is too powerful. Estimate its power by placing it on any iron or steel surface and note how much force is required to dislodge it.
In order to reduce its power, hold it over a range burner or torch for a minute or so. (Honestly, this amount of time is a guess. I "overcooked" my magnet to the point that it lost virtually all its power. The repair, however, was still successful.)
Check the magnet's power again by placing it on the same iron or steel object. It should be significantly weaker.
Reassemble the spindle clamp. Drop it back into place in the plastic top cover of the drive. Replace the thin, round metal cover over it. (In my case, the old glue was still good enough to hold it in
place. The spindle clamp will not pop out of the top of the drive- it is held down by gravity and by magnetic attraction to the spindle.)
Plug the unit in and test the drawer opening again. If it still strains but does not open, disassemble the spindle clamp assembly again and "cook" the magnet some more, then reassemble it.
After verifying that the drawer opens normally, replace the metal cover over the drive and the outer cover of the unit.
Dec 31, 2009 | Lite On LVC-9016G DVD Recorder/VCR
How to install driver side window regulator
1. Take door panel off by prying off with srew driver moldings for outside mirror,around lock,and door handle, then pry up counsel for power locks, windows, and mirror adjustment and disconnect plugs. Remove three screws located behind arm rest handle, inside where counsel was removed, and bottom middle of door panel. Lift panel and pull slighlty towards you. Disconnect courtesy light, and wire to speaker. This may sound like alot but it goes pretty fast. 2. Peel away plastic and loosen window glass clamps (explaination from above, which are accessable when window is in up position). 3. Disconnect wire to motor, and remove 6 bolts holding guide rails and motor. Lift rails slightly to release from little hangers, which come in handy when putting new one in. 4. You should be able to remove entire window regulator at this point. Surprisingly the window stayed in up position when regulator was removed. 5. Before installing new regulator loosen window glass clamps. Install new by first setting guides in place by using the little hangers. Bolt guides and motor, temporarily connect power window switch and carefully raise window regulator until clamps are resting in place under window glass, tighten clamps. Test before putting panel back on.
Jul 30, 2009 | 2000 Mitsubishi Galant
Document feeder jams
When you put your paper in, check the side clamps are set correct, if there is a gap at one edge, your feeding will be all over the place.
Tuck up the clamps to clamp the paper, not too tight where you bend the paper, but tight enough to hold it correctly.
Regards
Richard
Mar 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
Breadman TR444 Bread Maker Logo
50 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
