Question about Whirlpool GR465LXLS Electric Kitchen Range
Cooktop on indicator light stays on
All cooking zones are off but the red light stays on.
  • 2 more comments
  • hseiffert_7 Mar 19, 2009
    I have a whirlpool with the same problem. model # RF3750XPN, all the burners work, but when its turned off the right side indicator light is still on. What part do I need to change to fix this.
  • Anonymous Mar 24, 2009
    I am having the same problem...cooktop indicator light is on, but all burners are turned off.
  • 649tjs Mar 30, 2009
    I have same problem with indicator light to, it stays on, but all burners are off.
  • Anonymous Apr 08, 2009
    Same problem but with Model #RF386PAGN- Power indicator light stays on when power to burner is off.
aborcass
  • 2651 Answers
SOURCE: kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Posted on Apr 09, 2008
  • 105 Answers
SOURCE: Hot Cooktop indicator
You either have a reed or thermal limiter switch that is bad or a switch that is bad. The only way to determine it is with a meter. I think that this job is better left to a professional unless you know how to use a volt/ohm meter.
Posted on Apr 08, 2009
SOURCE: GE Profile JB 968 Hot Cooktop Indicator Light Always On
Temporary solution to turn off the indicator lamp - put a wet rag with an ice pack on top on the middle section of the cooktop.
The thermal sensor will trip off the lamp.
Posted on Apr 24, 2009
jyackle5
  • 8197 Answers
SOURCE: cooktop red light is staying on
The red light is on as a safety to let you know the surface is hot. When the light goes out the surface will be safe to touch with out getting a bad burn.
Please rate 4 thumbs for the free answer.
Posted on Mar 17, 2010
SOURCE: hot indicator surface light will not turn off
I had the same problem, but I found out it was only when one particular burner was turned on. I waited for the problem burner to cool, then took the fist of my hand and tapped on the burner itself and the light goes out every time. Works like a charm..probably a loose connection with that one burner.
Posted on Jul 24, 2010
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
Red light on kenmore cooktop stay on when is cold
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Jan 05, 2011 | Kenmore Cooktops
Red lights stays on
heatman101
Jan 05, 2011 | Kenmore 36 in. 42711 / 42712 / 42719...
One cooktop circle doesn't heat. Heat indicator light always on.
this could be cause by a faulty infinite switch,or the heating element has burned out
Sep 19, 2009 | Kitchen Ranges
Popping noise and red light
it could be a switch, element or a short somewhere else
Apr 29, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
Jan 03, 2009 | GE Profile JB968 Electric Kitchen Range
GE Profile cook top - four years old
unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
Dec 24, 2008 | GE 30 in. JP340 Electric Cooktop
Whirlpool GR465LXLS Electric Kitchen Range Logo
366 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
