Question about Zanussi ZWF1430W Front Load Washer
Error Code E90
I have a Zanssi washing machien and an error message E90 keeps comming up.can any one help.
Regards,
Trevor.
  • 1,029 Answers
It seems to be a common error code on some Zanussi models. This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts: Take the top off the machine, (ENSURE IT IS UNPLUGGED) and on the right hand side of the machine, you should see a set of 4 blue wires that go from the electronics module to the front display unit. Take this plug off (it is held on by plastic retainers) clean with wd40, or silicone (Servisol) contact cleaner, then dry, replace, then try again. If it is very badly corroded or pitted, you may have to replace that part of the wiring and socket.
If it is not that, then the wiring to/from various other sensors could be damaged, or the control board could be faulty. It is probably worth checking around other plugs and sockets, re-seating each one in turn, that lead to the control board, as they are expensive (£60 - £80). Pulling off and plugging back on (Re-seating) the plugs and sockets has the effect of cleaning the contacts, and may fix certain intermittent faults like this. Obviously check for any plugs/sockets that appear burnt, corroded, or discoloured compared with the others, and clean the contacts with emery or a needle file.hope this helps pls do let me know
Posted on Feb 09, 2009
What is e 80 on washing machine
Posted on Mar 22, 2016
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Frigidaire Atf6700fs2. Machine is giving me message E90. Can someone tell me plz what this means? Ty
    The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Read more: http://www.ehow.com/info_12017619_frigidaire-e90-error.html#ixzz2kK4eIkIS
    Nov 09, 2013 | Washing Machines
    It is flashing E90
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
    Good luck.
    Jun 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
    Machine flashing E90 and not working.
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
    Jan 16, 2011 | Washing Machines
    I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
    Jan 10, 2011 | Washing Machines
    E90 on Front load washing machine
    E 90 is an error code regarding the main pc board connection.
    the solution is to secure all connection to and from the main board.
    tighten the sockets and make sure they are not loose that could create a problem while vibrating and shaking.
    tnx 4 using fixya,
    drcool
    Sep 24, 2008 | Frigidaire ATF6000ES Front Load Washer
    Electrolux 1087 E90
    When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
    what can i do ?
    Sep 15, 2007 | Electrolux EW1000i Front Load Washer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi ZWF1430W Front Load Washer Logo
    701 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Chris Hall
    Chris Hall
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
