Question about OKI MICROLINE 280 Elite Matrix Printer
OKI ML 280 Elite
Hi im using this printer with my DELL PC. it dose not print rite, when I do a Test print. It prints some ODD characters ( eg. @@@@@@@@@EQT@@@@@) . Ive tried changing the Pitch and Mode and still comes out with the same result.
I believe there is no problem with the comm's as the printer starts to print once the command is given.
Would be a great help if someone could shed some light on this
Kind regards
Joseph
  • OKI Master
  • 838 Answers
You have the Printer emulation set incorrectly. I think it comes as IBM as default and you should try Epson instead. Its a trial and error thing but am sure emulation is incorrect.
Posted on Jul 02, 2017
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
keshy
  • 77 Answers
SOURCE: ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Posted on Oct 10, 2008
sys_admin
  • 829 Answers
SOURCE: font size
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Posted on Jan 11, 2009
Sphynkter
  • 221 Answers
SOURCE: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
SOURCE: Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Posted on Jul 22, 2009
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix... Problem
Be sure when you install new paper that the paper out switch, usually in the paperpath somewhere, is being contacted by the new paper. Usually located on the left side of the paper platten.
Jun 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Printing trouble
I think your alignment is out you need to get the printer serviced and aligned.
Dezzi
Apr 10, 2008 | OKI MICROLINE 521 Matrix Printer
Form feed length for 280
change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Feb 28, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Only printing tasks from some computers
Print the Menu Setting out on printer and menu setting out on pc. Match sure emulation matcheds on both sides. If using serial make sure serial settings match on both sides. If parallel, check the bois on the PC, change parallel port type to EPP instead of ECP or SPP.
Feb 13, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
Abnormal printing with continuous tone
this sounds like it is doing something called a "hex dump" basicaly printing all ASCII characters. okis tend to do this from time to time if l;eft on for a significant period with no data sent to it. the only advice given by oki is to switch it off when not using it unfortunatly Hope this helps Cops Pete@wedotoners.com
Oct 08, 2007 | OKI Pacemark 4410 Matrix Printer
OKI MICROLINE 280 Elite Matrix Printer Logo
201 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
