Cross Dewalt& 12" Double-Bevel Compound Miter Saw  Logo
Posted on Feb 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot rotate the Dewalt 708 mod 3 saw horizontally
I have a Dewalt 708 Mod 3 saw, 5 years old moderate to light use. When I try to rotate the saw to cut a simple angle the trigger depressed on the turntable but the turntable will not turn and the trigger does not return to locked position. As a novice repair person, I would suspect the trigger assembly that unlocks the turnable has failed but I don't know what the assembly is to check.
  • johnc_ilio Feb 09, 2009
    I cleaned the turntable a second time after reading your suggestion and I am back in business. Thanks!
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Feb 09, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1212724
Points
9283
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
  • Mike Wick
    Mike Wick Sep 29, 2021
    How to remove the turntable?
Where can I get a spring for my saw ?
How to Replace the Pivot Spring on a DeWALT DW708 ...
? 6:48
https://www.youtube.com/watch?v=xz3EPWHjj0A
Aug 9, 2012 - Uploaded by eReplacementParts.com
Dammaged pivot springs can prevent your saw's cutting head from staying upright and, as a result, cause a ...
Replacement Parts ' Pruners ' Loppers ' Saw Blades ...
coronatoolsusa.com/replacement-parts.html
Items 1 - 12 of 268 - $0.00 (0 Item). You have no items in your shopping cart. MyAccount · Login ... Spring for AG 4980SS. 4980-5. $8.53. Spring. 6310-5C. $7.11 ...
Shop for Where can I get a spring... on GoogleRecoil Starter Spring Homeli...$10.00eBaySpring Starter Chainsaw Ech...$4.99eBayHomelite 26lcs, 5?20, 5?30n, 6...$24.00eBayMcculloch Chainsaw Spr...$13.99eBay5x Husqvarna 362, 365, 371...$19.75BonanzaSearch ResultsHow to rewind a pullstart spring - YouTube? 5:05https://www.youtube.com/watch?v=qTcL3_3leTkMar 13, 2010 - Uploaded by lenniepincherIf you ever need to rewind a un coiled pullstart spring. This might help you. It took me ... First pull of my chain ...Chainsaw Rewind Spring Replacement - Echo ... - YouTube? 3:38https://www.youtube.com/watch?v=oqcjL7W0XMAFeb 18, 2013 - Uploaded by RepairClinic.comThis video provides step-by-step instructions for replacing the rewind spring on Echo chainsaws. The most ...
Dec 12, 2015 • Garden
19helpful
3answers
How do I calculate the mod function in my casio fx 100ms model
It seemed there is no Modulo function in fx-100MS. But Mod is just the remainder of a division operator.
So if you have A mod B = C, divide A by B, subract the remaining whole number, and multiply it by B to get C.
Example:
7 mod 4 = 3
In the Calculator:
7 / 4 = 1.75, then 1.75 - 1 = 0.75. Then 0.75 x 4 = 3
Hi my dewalt 708 lx sliding mitre saw, 110v, seems to only have half the power(speed) that it should have, and cannot cut timber on a compound cut because of this, any suggestions please.
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
I have a craftsman table saw mod. #1030206. need to know the year and how to get a manual. looks old.
tried 2 different sites that I use and the number is not coming up. Suggest calling Sears at 1-800-252-1698 for help
4helpful
Dewalt power saw wiring diagram for trigger switch dw-708 type 4 wire colors to swith positions.
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Apr 12, 2009 • Dewalt Saws
2helpful
I need a switch for an old Craftsman Sabre Saw Mod. 315.17180. Sears says they no longer carry that part.
Craftsman doesnt carry parts for tools once they hit ten years old. However, you can bypass the switch - that is remove it and just connect the two wires together. Then plug it into any power bar that has a switch.
3helpful
2answers
Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Top Cross Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Cross Saw Expert? Answer questions, earn points and help others
